Question about Cozy (W352E) Heater
Have a cozy heater cdv335 pilot lights but won't turn on
When I turn on the thermostat it does not kick on
hotuna
  • 288 Answers
SOURCE: Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Posted on Dec 23, 2007
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
shastalaker7
  • 1515 Answers
SOURCE: I have a W355F Cozy wall heater. I lit the pilot
I would take out the new stat and return it.Just because it was new doesn't mean it didn't have a factory defect. I see this all of the time buying a/c and Heater parts that I have to return for credit.
Good Luck, Shastalaker7
PS It sounds to me like you know whats up.Sincerely, Shastalaker7
Posted on Nov 06, 2009
shastalaker7
  • 1515 Answers
SOURCE: Cozy wall furnace burner will not light. Pilot
Hi, have done this to many times not to know. I will walk you through this. It is good that the pilot is lit. Go to the stat and remove cover. Don't worry as this is a milivolt unit, no voltage or such a small amount you wont even notice as this is why it is called milivolts.Take a small screw driver to remove the next section which is the thermostat and will expose the sub-base where you will find 2 wires connected to it. You may have 2 or 3 screws to take loose to get to this last section. Anyway, if you have a piece of insulated wire laying around, even old speaker wire will work, take it and touch the wire across the 2 terminals and hold. If the furnace comes on, the thermostat is faulty, and you will need to buy a new one. No power to shut down, and simple to change. Cost about $12.00 dollars. Try and get a heat only milivolt stat as they are much less expensive and will have less problems with them. Go to home DEPOT to get one, or O.C.S.H. will also carry them. Don't let the salesman talk you into buying a programable heat and cool stat, 24 volts as they will work, but cost more and you don't need it!! Look around even if you need to go to a wholesale Refrigeration, Air Conditioning, and Heating parts house. Tell them you need one for a unit in some apts you own, and you will pay cash as you want a cash account. They will only ask what job its for, and just tell them your name. This is not illegal and I wouldnt tell you this if it was!! You will still have to pay taxes but will get a wholesale price for it. I am sure it will fire up when you touch the 2 wires and prove stat is bad. For some reason it is not the stat, follow the 2 wires from the stat down to gas valve and jump the same 2 terminals there also. If it fires up, you will have a problem in the wires from the stat to heater and will need to be replaced. I don't think this is the case. But, on the chance it will not fire after you have done all of the steps I have had you do, then you have a faulty main gas valve(MGV) and will need to replace. This is all easy to repair.I am a 100% sure it will fire up when you jump the 2 wires together, and you will need the stat. Please let me know as I will be waiting for an update! Good Luck,
Shastalaker7
PS When you install the new stat, make sure it is Level.
Posted on Dec 18, 2009
shastalaker7
  • 1515 Answers
SOURCE: cozy wall heater does not turn on
Hi, I will walk you through to check the stat. Pull off the cover 1st. You will need a screwdriver, a small one. Could be slotted or phillips. Loosen all of the screws you can see until the t-stat comes off. You have 3 sections counting cover. You will now see the sub-base and wires. You should have only 2 wires to the stat. You will need a piece of scrap insulated wire, even a piece of old speaker wire twisted togeter at each end will work. No worry of shock. Just jump or touch across the 2 terminals and hold them on and if it fires up and comes on, the thermostat is the fault. More then likely that will be the problem. Any hardware store will have one. Get a heat milivolt only, even if the salesman trys to sale you a heat/cool 24 volt stat which will work, but will cause problems in the future. I am sure it is stat. If not, contact me and I will walk you through what else would cause this. If the pilot is on, there is no ignitor on this furnace, either a thermopile generator or a thermocouple, a high limit switch and the main gas valve. Keep me posted, it will only take you a few minutes to test the t-stat. Let me know.
Shastalaker7
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Air conditioner does not kick on when I turn down the thermostat
What kind of a unit is it? Is it integrated with a furnace in the attic? Need to now this information. Also, turn the thermostat to Cool/Auto and go outside to see if the condenser unit is running, if so, then there is a problem with the indoor blower motor or thermostat. Jumper the green and red wires on the thermostat and see if the blower comes on. If so, you have a bad thermostat. If not, you could have a bad fan motor or capacitor.
Jul 08, 2009 | Heating & Cooling
Not working properly.
REplace the T-Stat. It will solve all your problems. Also at the same time make sure your wires go to where they are marked.
R= red wire
W= white
Y=yellow
G= dont use
B=Blue
Jun 03, 2009 | Heating & Cooling
Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Feb 25, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Wheel fan would not kick on after electronic heater starts to blow air in ducts although the fan is tested in working condition
Did you recently replace the thermostat? If so you need a thermostat for electric heat. This thermostat will turn the blower on when the heat is calling.
Jan 25, 2008 | Heating & Cooling
Cozy (W352E) Heater Logo
290 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
