Question about United Stationers HP Officejet J6480 All-In-One Multifunction Color Laser Printer HEWCB029A
Printer is not aligned - hp j6480
When I print out pages they are crooked
    Problem Solver:
  • 9 Answers
You should have an icon on your desktop called "HP Solution Center." Click on the icon, and look for "Printer Toolbox." Open the toolbox, and there should be a button which will print an alignment page.
If not, then click open your Start Menu, click on All Programs, scroll down to HP.... and look for Printer Toolbox. and proceed as above. If none of this works, go to : www.HP.com click on Support for your device (model name and number) and you should be able to get an answer there... Good Luck.
Joel Bergmann
joelb21@gmail.com
Posted on Nov 04, 2012
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
My HP 2410 photosmart printer has started to print everything crooked. The paper is going through perfect but the printer left margin starts to increase about half way down the page. At the bottom the...
probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
May 09, 2011 | HP PSC 2410 All-In-One InkJet Printer
Printing out crooked...fix?
Have you tried to reset your printer, not just realign. Power down completely, you want to reset it and then align itself,
Jun 30, 2010 | HP Photosmart C7280 Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Alignment page is printing crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | HP PSC 750xi All-In-One InkJet Printer
HP PSC 500 is Printing crooked
Try this I think it will fix it.
Go to HP.COM.
Then select the Support and Drivers tab.
It will have steps to follow.
In step one select support and troubleshooting information.
step two enter your printer and then press go.
Now on the page that opens go to "solve a problem" and open it.
On the page that opens go down to "printing" and open it.
now open where it say"s "print quality." and open it.
Then select " printed text or image is skewed or crooked" open it. Follow the on screen instructions.
Oct 31, 2008 | HP PSC 500 All-In-One Printer
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Officejet J6480
Should be ready to go, return it
May 14, 2008 | Office Equipment & Supplies
United Stationers HP Officejet J6480 All-In-One Multifunction Color Laser Printer HEWCB029A Logo
73 people viewed this question
Top United Stationers Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an United Stationers Office Equipment and Supply Expert? Answer questions, earn points and help others
