Question about Forney At100 Arc Inverter Welder Lightweight Portable
Where to buy Forney at100 arc inverter welder?
Amazon had this product for sale. But it is currently available and they don't know when or if this item will be back in stock. The other websites have the same situation for this product. Is it discontinued?
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Forney model cb serial 145669 can't read front of welder.10 holes unmarked above low med hi
Here is picture of my Model CB. Based on the serial number it is slightly newer, but it should be close enough. Mine also came with a battery charger, which why it has the extra hole.11_22_2012_4_51_47_pm.jpg
Apr 07, 2012 | Welding Tools
Need wiring diagram for buffalo 110 amp. arc welder
They do not make it available. So a generic wirefeed such as this http://www.northerntool.com/downloads/manuals/628575.pdf will be reasonably close.
Rarely will the circuit board schematic be shown. If however your wire feed circuit stopped, usually it is the SCR's that fail and they can be replaced with comparable units, or even higher voltage and current ratings than the original within reason. http://www.digikey.com is a global vendor.
Jan 25, 2012 | Welding Tools
My CLARKE WELD 235 TEN TURBO WELDER BLOWS MY 13 AMP FUSE. iT ARCS UP THEN BLOWS FUSE
Hi well if it is blowing fuses and you are using it on a suitable circuit breaker, a FUSE really isn't suitable, unless a special Motor type slow blow fuse, etc esspecially with this much current draw, anyway if this is occurring the device must be short circuiting after it arc's, accordingly i would imagine that one or more of the output semiconductors, is shorting at this time, the only way to fix this will be to replace these semis? & possibly the drive circuit too? It's impossible to actually tell without actually examining the unit as i am sure you must understand?
However DIY in reality isn't really practical, unless you can obtain a service and repair manual, and then you maybe able to isolate and repair the unit, however in my experience the very best thing you can do is take it to a professional and get a "Quote" as top prospective costings and go from there? This way at least you will know what's wrong and how much it will cost, it may even be that replacement is better than repair in any event.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
I have an ancient 125 amp AC arc welding machine on which the current is varied by moving the negative lead from to different terminals. However the terminals are in pairs and joined by slotted metal...
Hi:
Since you did not mention here brand or model of welder; I'm pretty sure that your machine it's an AC/DC machine, the series of slotted plates means that the machine will output 50 amps in AC or 80 on DC. 60 in AC or 125 in DC.
If you want to work with lowest amps available, just put the selector on AC and connect your cables to the 50/80 amp side.
You should have a selector lever to switch back and forth from AC to DC in front of the unit.
Hope this work for you.
Jun 26, 2011 | Welding Tools
I have an old forney arc welder in my garage,WWII era. Would it be better to recycle the copper inside,or sell it via craigslist?As far as I know its fully operational and has the leads. What would be...
from the research i have done if you sell it on craigslist 100 is about the most you will get for it. unless you find someone who isnt smart enough to research. fron what i understand you can get about 200 if you dis assemble and recycle.
Sep 06, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
Nov 15, 2009 | Welding Tools
Looking for owners maual for Craftmans industrial ac/arc welder
You can find the manuals for sale for almost all Craftsman units at sears.com and navigate to the craftsman site and then to customer service parts and enter the model number and they will typically show you a parts breakdown of the unit and also offer replacement manuals for sale. Hope This Helps Don
Oct 01, 2009 | Welding Tools
Forney At100 Arc Inverter Welder Lightweight Portable Logo
Top Forney Electronics - Others Experts
Are you a Forney Electronics - Other Expert? Answer questions, earn points and help others
