Question about Sony Cyber-Shot DSC-W560 Digital Camera
Error code E:91:01 is connected with using flash.
Download the service manual from elektotanya.com and find the complete explanation to the error codes. This is a service center job.
Posted on Aug 23, 2015
SOURCE: problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Posted on Feb 17, 2008
SOURCE: Error code E:62:20 meaning
This appears to be a problem with a connector inside the camera. Try:
If these things don't work, it will have to taken to a service technician - it's quite expensive to repair, sadly.
Posted on Apr 14, 2008
SOURCE: error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT
YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Posted on Jul 06, 2009
SOURCE: my sony cyber-shot DSC-W70 is flashing an error
Click Menu
go to setup
then go to setup 1
and go to initialize
then click ok and then ok again
put in the right date and time then
click ok
That should fix your problem! ;)
Posted on Jul 27, 2009
SOURCE: My cyber shot DSC-T20 have a Error Code E:62:12
Press HOME> SETTINGS> MAIN SETTINGS> INITIALIZE> OK
Shake camera whilst it turns back on..may have to repeat a few times
The error E:62:12 is with sensor that tells to the camera in what position is it. (hor, ver..)
hope this helps you.
Posted on Aug 10, 2009
Jan 24, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Jun 18, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Dec 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Jul 06, 2009 | Sony Cyber-shot W110 Digital Camera
Oct 30, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Feb 27, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Nov 16, 2017 | Sony Cyber-Shot DSC-W560 Digital Camera
115 people viewed this question
