Question about Kitchen Appliances - Others
SR-1001 pilot does not stay lit
Hi:
You seem to know your way around this Berkeley Forge patio heater.
The pilot on mine only stays lit if I hold in the pilot button.
When I let it back out, no matter how long I wait, it goes out before I can get the control into run mode.
Any ideas on what to do?
Rgds
BIll Weir
weir@ix.netcom.com
408-210-7672
  • 1 more comment
  • phillybill Jan 12, 2009
    Thanks Carl -
    I have no idea how to replace it, or get a new thermocouple - do you have any help or can describe how to replace it?
    I do note that Berkeley Forge seems out of business so no idea how to get a new thermocouple - are these generic so I could try to use another brand's thermocouple?
    Rgds
    PhillyBill
  • phillybill Jan 17, 2009
    Thanks Carl - I am going to dis assenble and clean everything up and then see if it works - I had not used the unit in 2 years and I read where spiders and dirt can block the thermocouple....
    Rgds
    Rgds
  • 82 Answers
Replace the thermocouple
Posted on Jan 12, 2009
  • carl carpenter
    carl carpenter Jan 13, 2009
    most thermocouples are the same jsut the length is what you go by 18 in. to 72 in. should be a copper wire/tubing coming from the gas valve to the pilot light. it unscrews from the gas valve and either unsrews from pilot burner or just pulls out .hope this helps.
My heater lights but then does not stay lit (goes out after about 30 seconds). Any suggestions??
Sounds like the thermocouple is failed or really dirty with soote. When the flame lights and the thermocouple is in touch with the flame...it will create a minute amount of electricity which is sensed by the controler of the system. If it does not sense the flame then it will time out and shut off the gas supply regulator valve and pilot tube!
Oct 07, 2010 | Berkeley Forge G-PH001PSS Open Flame Patio...
Hole in gas line to burner
Get a replacement paty at your full service propane dealer. He would probably appreciate your gas business as well.
May 02, 2010 | Berkeley Forge G-PH001PSS Open Flame Patio...
Is there any way to find out what kind or where to get the correst thermal coupler for my Berkeley sr 1001?
These heaters are all pretty contankerous and I doubt the thermocouple has failed, unless something has been done to it (I've got two of these heaters, and have to work on them all the time. Have never replaced a t-couple.). I usually find the problem with the t-couple is insufficient pilot flame.
Problems fall into two areas -
1) Bugs building nests or spiders building webs in the pilot hood and main burner. Disassemble the top head and clean everything. While you have the pilot tubing disconnected, be sure to blow out the tube (by mouth), making sure you have flow. Also make sure you clear the air mix chamber in the base of the pilot hood.
2) The regulator in the bottom of the unit begins to stiffen up after 3-5 years of operation. I have found universal replacement regulators at the local Lowe's and Home Depot.
Make sure all t-couple connections are snug tight.
Let me know what you find.
Dec 16, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Can you telll me how many BTUs is has?
There is a UL plate on the heater it should strate the BTU's on it I did find this for you Berkeley Forge G-PH001PSS Open Flame Gas Patio Heater. Patio, Alimentation: Gas, Open Flame, 12000 BTU
Oct 12, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Kirkland outdoor heater will not stay lit
The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
May 31, 2009 | Stainless Patio Heaters - Steel Deluxe...
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
Berkeley Forge Outdoor Propane Heater Sunrise Model SR1001
I believe the company is out of business but I just got my heater fixed using a local gas service company. Took them a while to find a compatible thermocouple assembly but he found it so there is hope.
The unit works like new now except for the ignitor but not a big deal as it works fine to light the pilot with a lighter.
Jun 10, 2008 | Berkeley Forge G-PH001PSS Open Flame Patio...
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Kitchen Appliances - Others Logo
157 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
