Question about Dacor Ovens
Dacor CPS 130W clock board
Oven shuts off
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
SOURCE: Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Posted on Oct 10, 2008
vitg55
  • 70 Answers
SOURCE: Dacor CPS 130 oven will not heat
This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
Posted on Dec 18, 2008
  • 81 Answers
SOURCE: model cps 130w single conv oven makes excessive
Nothing easy to solve. If it is newer, it could simply be a mounting screw or bolt loosening. If it is older, it could be the motor bearing. Noise described is so nebulous. It will require you checking it yourself by pulling everything out or calling a repairman.
Posted on Sep 01, 2009
ginko
  • 19396 Answers
SOURCE: Hi, I have a dacore
Hi.
It sounds like a defective control board.
First ensure that it is not a setting problem, that the oven is not in timed bake mode, and that the oven is not in Sab mode (control locked for three day), or in Holiday mode. If oven is in Sab mode, it is still malfunctioning, as in this mode the oven is not supposed to start at all.
Contact Dacor using this form , include full model number, and descibe the problem accurately. They will tell you if the problem is setting related.
If the problem is not related to settings, and the oven goes off on its own, then the timer board is usually the culprit. Since the timer board(oven electronic control) is expensive it is better to have it tested before replacement. Testing timer board consists in summary test at component level, voltage reading during operation and testing of other parts that can cause the problem.
One part that must be surely tested before replacing timer board is the door lock. Ensure also that the connection to wallsocket is OK.
Regards.
Ginko
Posted on Nov 05, 2010
I try to set the clock on the oven but pressing the CLOCK touch pad or the TIME-TEMP pad has no affect. It is completely nonresponsive.
It sound like the board is faulty, its quite common after power surges can cause damage to small circuit boards like clocks, I would recommend changing it as the clock will also provide timing for switch on at a set time cook for time as well.
http://dacor.com/Search.aspx?query=ECS227 Epicure Electric
Hope this is helpful
Regards
John
Oct 31, 2014 | Dacor ECS227 Epicure Electric Double Oven
Dacor Oven model # CPS127 - part # 13158B - discontinued. How to find
More than likely your not going to be able to find a part once its been discontinued, especially if its been that way for a while, but there is an alternative though. There are companies that specialize in rebuilding control boards, etc that have been discontinued and are no longer available. I would contact a company like appliance parts depot or another major distributor because they will have the numbers you'll need to contact those companies, but remember, whatever the cost of the part was is nothing compared to the cost they charge to remake the part.
Jun 21, 2012 | Dacor Ovens
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
Dacor ECS230 oven cannot set clock. Push clock button nada.
Any display at all? If not then hunt for one of these in the wiring connecting directly to the oven control. Then try to locate the fault such as bad fan etc.2295727.jpg
Mar 17, 2010 | Dacor ECD230 Epicure Electric Double Oven
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
Model cps 130w single conv oven makes excessive noise when turned on. It just started doing this a couple weeks ago.
Sep 01, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
Aug 25, 2009 | Dacor ECS230 Epicure Electric Double Oven
F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Jun 29, 2008 | Ovens
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
