Question about Garden
How much and what type enine oil in an ariens 5520 sno thro?
5 Suggested Answers
SOURCE: How to install spring on Ariens chute
Not a DIY fix as took the snow blower into the shop for them to repair it.
Posted on Oct 21, 2009
SOURCE: Oil used for a Ariens 932 series 2+2 Snow Thro?
It takes SAE 30 oil.
Sam
Posted on Jan 08, 2010
ToolBoxHero
  • 171 Answers
SOURCE: where is the spark plug
I am assuming this is a 22 or 24 inch model. The engine is an overhead valve design and the spark plug is buried on the left side of the motor (looking at it from the handles) You should be able to see a large black wire going into the engine. Depending on the engine make it may have a rubber cover or just plug wire covering the plug.
On this page are pictures showing the location of the spark plugs on Briggs & Stratton engines.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Identifying%20the%20correct%20spark%20plug%20and%20gap.aspx
The OHV horizontal shaft engines are about half-way down the page.
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
ToolBoxHero
  • 171 Answers
SOURCE: i have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Where is the spark plug located on an Ariens Sno-Thro compact?
Jan 13, 2011 | Ariens Garden
I hav a new Ariens Sno-Thro Cab kit, purchased as an open box from my dealer. There are no assembly instructions - I could probably figure it out anyway - and there is a part "B1" which implies...
B2 is the other side's lower handle bar to liken it to a bicycle scenario. You are SOL without it. Contact Ariens or Classic Accessories, the maker. B2's name is "Side Mounting Bar".
Dec 26, 2010 | Sport & Outdoor - Others
Oct 20, 2009 | Ariens Garden
Garden Logo
419 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
