Question about iRiver H10 MP3 Player
Cannot delete or add music to iriver h10
When we try and add or delete music the computer says it is done but now the iriver will not even play songs and all the deleted titles are still showing up on the screen
  • carlton_c Jan 07, 2009
    Iriver H10 20GB will not sync any new songs. WMP shows that files already on H10 are syncing, but new songs will not sync and WMP continually displays message that it is syncingt . I have an iriver e10 that syncs just fine, so wondering if something is happening with H10 similar to what happend with Zune
I had this problem at first too. the only thing you have to do after it's done syncing disconnect it and turn it on. then afterward go through the options till you find database refresh and wait for it to refresh and all your new music should be in it.
Posted on Jan 14, 2009
Cannot delete musice from iriver h10 need to know how
I presume that you are running the original firmware with windows media player to add your music.
There is an option on the Sync screen to delete.
Let me know if you are not using WPM to add your track to your h10
Jun 09, 2009 | iRiver H10 MP3 Player
Iriver won't let me upload from CDs and transfer....
Best way to use the H10 20gb is by creating a directory on your hard drive with your desired mp3 format files. Use ripping and encoding software with your existing audio cds.
Connect the h10 to the PC via the UMS trick (see this website).
Using a file directory on your pc, drag and drop the mp3 files from your pc to the MUSIC file folder on the h10. Install and run the EASY10 playlist creator software on your pc to organize the new files on your iRiver player. Disconnect the USB connection and enjoy!
Mar 22, 2009 | iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Iriver Troubles
Delete the playlist and try to re-add using windows Media Player - make sure EVERY song in the playlist is in the right format
Mar 31, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
New computer - will I lose music files when I connect iRiver
I have also changed pc's and took the chance on losing my music, I've found that I didn't lose any of my music it just keeps adding and updating
Dec 20, 2007 | iRiver H10 MP3 Player
Iriver H10 20GB
They don't make a battery for the player. My experience with iriver is that they only replace your player with another refurbished one if it's under warranty. Contact iriver.com and go to support, they will help you to a certain point. Sounds like some music files are corrupted, did you download them from Limewire? Lots of nasty stuff out there. Remember your player is a Hard Drive just like your PC and can be damaged by improper disconnect from your PC. Regards, John H.
Feb 07, 2007 | iRiver H10 MP3 Player
Iriver doesnt play songs any more...
I had the same problem and i fixed it by updating the iriver firmware
Jan 30, 2007 | iRiver H10 MP3 Player
I can't hear any music
Replace - cannot be repaired
Dec 14, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
374 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
