Question about RCA Audio Players & Recorders
Rca rtd3136 eh audio problems
Sound is intermitent and sometimes crystal clear (like during previews) and then when the movie plays the dialogue cannot be heard.
SOURCE: Music track is heard, but dialogue is not
FBI notified crooks
Posted on Jan 06, 2008
SOURCE: my coby dvd 925
Go to setup and change it from 5.1 to 2 channel audio. I have no idea why, but it worked for me. Cobyusa.com/solutions is where I found it at. Good luck.
Posted on Mar 20, 2009
bshldn
  • 736 Answers
SOURCE: When I play DVD's theres
When this happens changing the audio output setting will sometimes fix that problem. Within the menu of the DVD player if it is on bitstream change it to pcm (might say 48khz or 96khz). If it is already set to pcm then change it to bitstream. If you can chose whether or not to have secondary audio on or off make sure it is off.
Posted on Nov 24, 2010
SuperTech-11
  • 1591 Answers
SOURCE: snow and wave lines appear during movies, while
CHECK THE VIDEO CABLE FOR A BAD GROUND (ESPECIALLY IF YOU HAVE PETS)
Posted on Mar 08, 2011
dunnbiker
  • 8546 Answers
SOURCE: Just bought an RCA RTD317W home theater system.
Barely or not at all?
The previews are almost always in a format-neutral audio track, like stereo. Once the feature starts you're usually listening to a multichannel soundtrack.
The dialog of a movie is usually carried on the center channel. Check to make sure you can hear and adjust test tones on all speakers per the manual first.
Posted on Jul 12, 2011
I have an RCA RTD3136 theater system, bought new in 2013. Worked fine for a few months, then started going out occasionally. I'd unplug the unit and reset, and it would work fine,for a while.
It sounds to me like the audio output transistor or IC is going bad,or the unit is overheating.Try blowing the unit out with canned air and relocating it so it can(breathe)<dissipate heat .
Nov 12, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Yamaha receiver problem
Yamaha offers a lot of audio configurations and you may have changed the one that places dialogue in the center channel. I have found that some experimentation is required to get the desired result.
Mar 14, 2014 | Audio Players & Recorders
Only background sound, no dialogue when playing blu ray
do you have a center channel speaker hooked up? Most dialogue in movies should come from the center channel.
Feb 28, 2014 | Onkyo TX-SR605 Receiver
Can you use dvd without speakers
Yes, go to your Television menu and system settings, select sound source and set it to internal speakers
Feb 15, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
No audio playing blu ray movie. previews on same disk play audio. using digital audio coaxial cable
I'm guessing there's an unnamed BluRay player in here somewhere. IT has audio settings and each movie might also have setups for the Main Feature. Previews and menus are always in the lowest common audio denominator.
This unit can only accept Doby-Digital or PCM digital audio. DTS, for example, is not supported.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2580-Receivers-manual/id/23292ag604/t/2/
As it says on page 4, "Read instructions carefully when connecting components to the receiver."
Read the Blu-Ray manual.
May 17, 2011 | RCA RT2580 Theater System
When I use the headphones listening to TV, I get the background sound (eg music) clearly but the dialogue is very low and drowned out by the background music or ambient sounds
It's because the TV's audio is stereo and the dialogue is mono split between two channels. When dialogue hits your headphones the majority of the mono signal gets cancelled. Try a different set of headphones or watch true stereo channels... IE movie channels
Apr 18, 2011 | Bose QuietComfort 2 Acoustic Noise...
WHAT SHOULD I DO THREE OF MY SPEAKERS DOES NOT ON TWO REAR L-R AND THE CENTER I PLUG IN THE BLURAY PLAYER AND FROM THERE USE MY HDMI FROM THE BLURAY PLAYER TO THE HDMI ON THE SAMSUNG FLATSCREEN TV ANYONE ...
Hello there,
It sounds like everything is working correctly to me. Voices / spoken dialogue should mostly be from the front speakers and surround audio (music, effects, etc) from all speakers.
The TV screen is in front of you so the people on the TV screen are also (technically) in front of you. Naturally, I would expect the spoken dialogue to come from the front speakers only - except in some instances, where dialogue in the movie is from a character not currently on screen. If you had voices from both in front of and behind you when the characters are only in front of you, it would be totally disorientating.
If you have audio from all five speakers during a movie then all of your connections and settings are correct. The problem you are describing is really just a description of how surround sound works.
I hope this helps. If I misunderstood the question or the problem, please let me know.
Regards,
BElectric.
Mar 08, 2011 | Samsung Audio Players & Recorders
Audio
uninstall the audio driver and then restart the PC and reinstall it if the problem presists then search the update driver and install it.
Dec 30, 2007 | CyberLink SW- DVD Software Power DVD...
My coby dvd 925
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
Ray
raybuhr@yahoo.com 469-438-3979
Nov 19, 2007 | Coby DVD-925 System
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
