Question about Lavazza 2210
Need service on lavazza blue LB 2210
My warranty on my lavazza is up, and my provider does not fix the machine,, my lavazza has a problem when im making coffee, I insert the pod, the water goes inside the draw and no coffee comes out, then the pod falls into the tray but it has holes in it,, my other problem before this was that the pod wasnt falling, but with troubleshooting we would resolve it once in a while,, please help ,, i leave in the glendale queens area in new york,,,
  • 3 Answers
For more company or product information please call us at 800-524-2343 or email us at info@betson.com
Posted on Jun 05, 2012
    Problem Solver:
  • 19 Answers
Contact me @ www.lavazzarepair.com
Posted on Nov 12, 2009
    Problem Solver:
  • 10 Answers
It sounds like your 2210 needs some new gaskets and new piercing crowns, there are plenty of authorized lavazza service centers in the NYC area as this is their US headquarters.
Posted on Aug 25, 2009
Error code 11 lavazza blue
Lavazza LB 2210 error 82/84
Aug 20, 2013 | Lavazza 2210
My lavazza blue esspresso machine lb2200 displaying error-21
Power down, press and hold language button, power up and the machine should go through a rinse cycle and start heating. That is what I did anyway and the fault cleared .
Mar 01, 2013 | Coffee Makers & Espresso Machines
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Jul 08, 2011 | Lavazza 2210
I am considering buying a Lavazza LB2210 Espresso Machine. Owner says the screen says "fill with water" after she descaled the machine. What kind of cost am I looking at to get this fixed?
There is a floating plastic block in the water chamber that sits next to a sensor in the machine, that tells the machine whether the water reservoir is full or not. if its stuck, that could be the simplest fix ever. It could also be the sensor at fault, but it should be easy to test the float first
Sep 24, 2010 | Lavazza 2210
Just need instructions to descale my Lavazza Blue coffee machine
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Sep 05, 2010 | Lavazza 2210
Pls tell me were is lava mobile service center in
have a new lava A9. But it hangs when the warranty registration promts to register warranty service, which propts regularly within few hours. So please suggest how to register warranty service or to stop propting.
purchase A New Hand Set 05/01/2011
Mar 17, 2010 | Lavazza 2210
Machine is plugged in...but when the switch is flipped, the machine refuses to turn on (yes there is power to the outlet).
Could be a defective power switch or open line cord/plug. You will need a voltmeter to determine which is at fault.
Mar 06, 2010 | Lavazza 2210
Lavazza point espresso machine no steam
Sounds like a clogged steam pipe or a jammed two-way valve. First, I would try unfolding a small paper clip and then stick it up the spout of the steam pipe. if this does not free up the steaming arm then it is most likely a clogged two way valve. Should you need service you can call 781-393-2929. we are an authorized lavazza distributor and service center
Jan 06, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza 2210 Logo
1,771 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
