No heat in nisson armada - Computers & Internet
  • 7,627 Answers
Re-boot!
Posted on Nov 04, 2012
2004 nissan armada whats code p1759
sounds like you have two problems trans problem& a over heating.most cars are fix to kick the ac off wen the car over heats
Sep 09, 2012 | 2005 Nissan Armada
What kind of gas to use after 75,000 miles (Nissan Armada 2005)
The gas you use shouldn't change after any miles. Keep it to what the factory recommends. You'll be wasting your money if you put premium and it only needs regular.
Dec 09, 2010 | 2005 Nissan Armada
Hello, I've imported into Canada a 2006 Armada LE from Arizona. Now that we're into cooler temperatures with vehicle heat required I find the heat output in my Armada lacking. The heater does produce...
tha anti freeze mizture should not matter, coolant should reach a running temp and stay there , i would look into a thermostat, and check the mix doors, it may not be giving you full heat,
Oct 27, 2010 | Nissan Armada Cars & Trucks
2004 nissan armada no heat
if the truck has rear heat than you most likely have a coolant leak by the rear of the vehicle, causing the coolant level to be low in pressure tank causing loss of heat. to replace those lines you need to lift the vehicle from its frame about 18" and get those lines repleced. if you dont have rear heat, just try adding some coolant into the pressure tank, not the radiator it self.
Dec 26, 2009 | 2004 Nissan Armada
Nisson almre se indicator lights not working
sounds like the flasher is bad. you can get one from autozone.
Nov 14, 2009 | 2003 Nissan Altima
Questions regarding an outside mirror
Heated mirrors have a swtch in the car. That operates the eliment that is stuck to the glass.This eliment heats the mirror when turned on.It is used to defrost or demist the mirror.A none heated mirror has no wires going to it and no eliment at the back off the glass.OK.
Aug 01, 2009 | 2004 Nissan Maxima
2006 Nissan Armada, front blower for heating and air doesn't work
Your could check to see if the blower switch has gone out. On the main unit. Posibly the wire harness conection might have came loose inside the dash area. Check the fuses just to make sure they aren't on separate circuits.
May 01, 2009 | 2006 Nissan Armada
My 93 nisson quest has no heat but is overheating
bad water pump or clogged system. is the car overheating, if so water pump. take off the radiator cap, then start your car, if you can see antifreeze swirling around, pump is ok, if it looks like it's standing still, waterpump. And a clogged system, might not be the only problem, it's just the more, common issues.
Feb 06, 2009 | 1993 Nissan Quest
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
