Question about RCA P52926 52" Rear Projection Television
The picture has bowed and the colors are not aligned
  • davidjont Jan 06, 2009
    my 60" rca rear projection is bowed on bottom of screen yet picture is otherwise fine.
  • Carter Bennett Jan 13, 2009
    My TV seens to do the same thing it looks almost like a double image with the screen bowing down from the top and up from the bottom. It used to happen every now and then now it only runs for about 15 min. before it goes wacky. It seems to have a very high pitched sound when it happens.
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below fothe picture has bowed and - 69189a5.png/>
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
  • 61 Answers
SOURCE: Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Posted on Mar 07, 2008
SOURCE: Sony kp-53s35 bowed picture on top and bottom
Big Irish, you were right on. I brought the tv in to a shop and ha dit diagnosed, a convergence ic was bad, they ordered me one and I soldered it in and got it working. ready for this I spent a total of $272 for diagniosis and part. in my op[iniom that was not bad at all tv has been working for over a month.
Posted on Jul 19, 2008
SOURCE: 51mp392H/17...bowing and color alignment off
Take the TV to a repair shop. It sounds like the convergence chips are bad. Be sure they change them as a pair or you'll wind up with the same problem again.
Posted on Dec 13, 2008
  • 10 Answers
SOURCE: BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Posted on Dec 18, 2008
  • 1030 Answers
SOURCE: Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Posted on Mar 15, 2009
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
My Toshiba projection screen TV the picture is bowed and the colors don't line up
3d colors not lining up poblem dicates "convergence issues.. bowing piture may indicate complete faliure of convergence alignment cuircits... depending on model the most likely cause will be 2 micochips (ic's called stk<s)
Aug 23, 2010 | Toshiba Televison & Video
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Bowed picture colors off
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 02, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture bows in towards middle
YOU HAVE A ALIGNMENT PROBLEM, ON YOUR BOW OR PINCUSION, OR A BAD RESISTOR, THE COLORS NOT LINING UP COULD BE A CONVERGENCE PROBLEM. I ADVISE YOU TO LET A EXPERT TO THIS DUE TO THE HIGH VOLATE ON THE CRT(PICTURE TUBE)
Jun 07, 2009 | RCA Televison & Video
Mar 09, 2009 | RCA R52WH73 Projection Television
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
191 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
