Elite 100 legend pocket scale error code f--h
When off i hold on/off, then as i let go i hold mode it pops up --0.30.. other then the error code f--h comes up
2 Suggested Answers
SOURCE: when I turn on the pocket digital scale there are
threw it out the f____n window
Posted on Jan 17, 2010
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My digiweigh scale reads HHH. What does this mean and how do i fix it?
It worked on mine,
I pushed Mode, Power, Tare at the same time.
It came up in Cal mode.
I added penny's till it was 995 or so then added small pieces paper to it till it was 100 then up popped passed. I turned it off then it works fine now.
Thank You!!!!!!!
Oct 19, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
F--H APPEARS WHEN TURNED ON AND FREEZES
that dosent work in the case of an f--h display at least in my case i think the f--h stands for f**king hopeless
Jun 17, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
