Question about Nvidia Ecs Geforce6100pm-m2 V2.0 Amd Am2 Ddr2 Sata2 Desktop Motherboard
My computer is switching off whenever you switching him on what is the problem you must know also that i changed the power supply
The motherboard is AMD and have the computer for three years , at the first my computer started the problem I changed the power supply as someone advised me to change that and it will be well . the RAM is 512mb the hard disk is 160GB and I add 500GB that is all from me thank you .
  • joecoolvette
    joecoolvette Nov 05, 2012
    I have to ask; dirty inside? (Plus 512MB's of Ram Memory? That has to be a slow computer )
  • Nvidia Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible
hope this helps
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
you could use a multimeter to check it
Test all power and data leads that attach to your hard drive IDE,SATA
if its a 40 pin flat ribbon type it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
check all power and data leads make sure they have secure dust free connections
check you CPU make sure its securely seated and has thermal grease
hope this helps
Posted on Nov 05, 2012
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
My imedia b2217 will not boot. Is the motherboard dead? Whenever I switch on the computer nothing happens. No lights, no fans, nothing at all. I have replaced the power supply but still nothing
Hi i'm Basti,
How bout the fan for your power supply, is it running? Try to retrace the cables to motherboard and make sure its tight. Change or use another power supply if possible.
Keep me posted. Hope this helps.
Feb 25, 2011 | Packard Bell iMedia SL 9553 (P660401806)...
When I start up my computer, nothing happens. The hard drive doesn?t spin, the fans don?t work, nor do I get any display. I?ve checked the power strip and know that power is getting to the computer, but...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 06, 2010 | Computers & Internet
Whenever i try to turn the computer on, it does flash on and then goes off almost immediately> I have replaced virtually everything..The CPU, The Power supply, The Mother Board< Graphics...
RAM might be one of the major issues.
You should have started trouble shooting by changing the RAM
If you have more than one RAM module try one by one.
Also try clearing your BIOS settings.
Nov 21, 2010 | ASUS P5VD2-MX SE Motherboard
Power to Motherboard but will not bootup?
most likely a failed hard drive as all of the boot requirements are on it
Apr 24, 2017 | MSI 694T PRO (6309-470) Motherboard
My HP Pavilion a1050y won't boot up.
So you've checked the supply, but you didn't replace it, right? Sounds to me like that's your culprit. It's not able to supply the current to run the processor (the biggest draw) and the output is dropping too low to run the system. A new supply should get you running again.
Mar 06, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
My asus a7n8x motherboard based computer won't switch on - I press the power up button - and... nothing!
First try switching the power cable that goes from the power supply to the wall switch. You would be surprised at how many times that is the case. If you know for sure that power supply cable is good, You possibly have a bad power supply. You can purchase these for about $40.00 at most of your computer stores. But before spending your money on the power supply, make sure that the switch that turns on the computer is not bad. a- check power supply cable b-check computer on/off switch c-check power supply. Good Luck
Jul 14, 2009 | Computers & Internet
My motherboard can't turn on and me had changed power supply with new one.Can you help me how to check power on motherboard.Thank you. I bought a new case for my ATX motherboard. I installed the power...
the chances are that the power supply is not enough for the motherboard. or the main power connector has only 20 pins. the newer version of motherboards requier 24 pin power connector.
Mar 24, 2009 | Computers & Internet
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Mobo no boot after changed power supply
I couldn?t find much on the motherboard either. Over the years I have only seen a handful of boards with fuses so I doubt you have on your board. -Double check the new power supply and ensure it is designed for your motherboard. -Double check the power supply connections to the motherboard, the connectors should mate up exactly to the motherboard. -If you did remove anything double check for shorts, grounding and so on. Any of those can cause the same symptoms. -Test the case power switch, it could be bad. -Some power supplies have on/off rocker switches on them (in the rear by the A/C power socket), make sure it?s on. -Most power supplies have a 115/225 volt switch in the rear by the A/C power socket; make sure it is set to whatever is appropriate for your country. I assume you use 115V like we do down here. -Make sure the A/C power cord is working. -Test the power supply in another computer or if not available you can generally pickup an inexpensive tester for $10 to $15 at a computer store that sells parts. -If you get this far and still have no solution then my guess would be the old power supply had a power surge on its way out and damaged something major on the motherboard. You can look on the motherboard for obvious signs of damage; however, unless you know what you are doing I don?t recommend the typical user try to perform repairs of this sort. Let us know how things go or if we can help further.
Jan 01, 2007 | Foxconn K7S741GXMG-6L Motherboard
Nvidia Ecs Geforce6100pm-m2 V2.0 Amd Am2 Ddr2 Sata2 Desktop Motherboard Logo
178 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
