Question about Gaggia Classic Espresso Machine
Gaggia Steam Nozzle
I do not know if you can help me.
I lost one of the 2 rubbers of the steam nozzle of my Gaggia Classic. Is there a website I could order it from? I suspect that I will have the entire part of the steam nozzle.
Thank you in advance for your help.
Best regards,
Gerry
    President:
  • 1,618 Answers
There is a sit where you can get the parts for the gaggia it is at WholeLatteLove.
Posted on May 18, 2009
No steam coming from frother
If you are getting hot water from the grouphead to make coffee then the nozzle at the end of the steamwand could be blocked, use a paperclip to clear. If the problem is not fixed after cleaning nozzle then machine need to be descaled.
Oct 02, 2011 | Gaggia Classic Espresso Machine
Need assembly instruction for gaggia titanium steam wand. doesnt seem to go far enough up the tube after i cleaned it
Slide the large sleeve off, now you have just the shorter plastic nozzle with the rounded cap. Unscrew that cap - hold the plastic nozzle with one hand while twisting the cap to unscrew it.
Inside is a hard plastic ring and a soft rubber sleeve. Sometimes the soft rubber sleeve will not come out of the nozzle - if so then just leave it in - but if it will come out, take it out and clean everything really well.
OK ... now put the cap on the steam pipe, then the hard plastic ring, then the rubber sleeve - and slide them up high enough on the pipe - then slide on the nozzle last. Then tighten the cap down on the nozzle until it is gripping good and tight. Then slide the long outer sleeve and you should be good to go.
Oct 01, 2010 | Gaggia Titanium Espresso Machine
Hi, my 4 year old gaggia classic coffee machine's steamer no longer works. The coffee bit still works fine, but when i twist the knob to let the steam through, nothing happens. Can this be fixed easily?
It could be that the nozzle is blocked, and or the steam valve is blocked. Try descaling machine, if that does not help then you might have to remove steam valve to make sure it is not blocked.
Jul 02, 2010 | Gaggia Classic Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
No steam
Is the coffee hot or cold?
If hot then the steam wand is clogged, try inserting a paperclip in the hole(Remove the parnello black plastic covering silver steam wand) at the end of the nozzle.
If cold then the element is not heating, if you remove the top panel on the machine there is a thermostat on the boiler. That might be damaged, some of them are resettable (it will have a red or brown pin in the middle) if it is a resettable one then push in the pin, if not then it will have to be replaced.
May 17, 2009 | Gaggia Classic Espresso Machine
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Feb 27, 2009 | Gaggia Carezza Espresso Machine
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Jan 14, 2009 | Gaggia Classic Espresso Machine
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Classic Espresso Machine Logo
271 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
