Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence! I have the same problem wiith my Magnavox could you take some pictures of exactly where you put the chips? I'm only 14 so please explain in a way that 3rd graders could understand.
  • tararue1017 Jan 09, 2009
    would this be the same reason the picture will curve in the bottom of the screen? Also the colors were off like a 3D picture. If this chip is fixed would this fix the problem.
Convergence! - 8d79a45.jpg Where his left hand is at is where the Convergence chips are. They will have accordion looking piece of metal on the back of the chips. I would have some one with a few years experience on elctronics replace them for you. They are delicate!
Posted on Jan 07, 2009
Just wondering what the cost would be to add coolant to the green and blue bulbs, and change the computer chips for these 2 as well.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Philips 60PP9202 60" Rear Projection...
It appears to be convergence issues. Red, green, and blue are very seperate. Yoke adjustments will not bring the RGB in. Is this possibly a convergence chip issue?
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Mar 29, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
"convergence chip failure"
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Oct 05, 2009 | Sony KP-43T70 43" Rear Projection...
We replaced the convergence chips & 1 3.5 pico that was bad and no changed --it still looks arched on the outside and now can move the crosses on the manual convergence but they outside still wont line up...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
May 03, 2009 | Sony KP-65WS510 65" Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hello, I have an older Pioneer SD-P55A3 projection tv. I have a problem where the picture at the bottom of the screen appears distorted or, more accurately, "warped". There is yellow and blue that does not...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Mar 16, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Magnavox 51" Model # 51MP392H/17 problem.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Mar 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red "aura" in the middle of my 55" Phillips Magnavox
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 55" rear projection tv
It is probably your convergence chip.
Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 28, 2008 | Philips Magnavox 55P9271 55" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
