Question about Hoover Tempo Widepath Upright Vacuum - Blue
I turned it off, now it won't turn on
It was working perfectly, I turned it off for a minute and it would not restart. It is several days later and still will not start. I followed the trouble shooting guide with no benefit. It is about 2 years old.
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
Sweeper stopped after using wand
Hi there, it's Jack at Dyson.
Most of our vacuums include a thermal cut out, which shuts the machine off if it starts to overheat. Usually this will be because the filter needs a wash, or because there's a blockage in the machine. From what you've described it sounds like there's a blockage in the hose, wand or duct.
To resolve this, please follow the steps shown in our online Support guide: http://content.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
It's important to wash your machine's filter at least once every 3-6 months, as shown in the video above. Use cold water without detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve the issue, but if you would like some further advice from our experts, please email us at askdysonUS@dyson.com. We'll be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 30, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Stops
I had the same problem when I renovated my kitchen. With boxes of stuff everywhere it was impossible to use Roomba. When I tried to use it again a few months later, it would stop after only a few minutes work. I had to buy a new battery which cost in excess of $100. Its better to loan it to a friend to be used than to put it into storage.
Apr 30, 2013 | iRobot Roomba 530 Robotic Vacuum
My bissell 6583 worked fine for 2 years no problems . Today I vacuumed my sons room, turned the vacuume off, 2 hours later it won't turn on... Help please I'm in the middle of my spring cleaning.
Hi Mary. I can understand how frustrating this can be especially when Spring cleaning.
Here is a quick link to troubleshooting steps to assist you with the no power: http://www.bissell.com/FAQDetail.aspx?id=1457&cid=ccsocial
Apr 14, 2013 | Vacuums
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
Machine turns on, has little suction, then stops working.
It would be helpful to know what model of vacuum cleaner you're talking about. Basically though, your machine has a blockage somewhere (hence very low suction), and is cutting out after just a few minutes because of overheating.  You need to explore the suction hose (or whatever your machine has), find the blockage and remove it. Blockages almost always happen where the pipe-work takes a sharp bend.  In the worst-case scenario (although in almost all modern machines this is not possible) the blockage may be in the vacuum fan enclosure itself, and then you'll probably need a professional to take care of it.
Feb 03, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover Tempo Widepath Upright Vacuum - Blue Logo
51 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
