Question about Kenmore Dishwashers
Need to find door handle latch for kenmore dishwasher 154355101
Door will not lock, needs new door latch
  • 2 more comments
  • Debby GreenMitchel
    Debby GreenMitchel Nov 04, 2012
    alright hey Thanks for that.. just found the # on the door when I dropped it down. Was afraid that was too easy.. will have a closer look at the unit and go from there. Really THANKS MUCH
    Debby GreenMitchel Nov 06, 2012
    migh5t ask one more thing.. looked inside,on back (all around) and on sides as well.. Have a bad feeling the model number might be on the bottom? Is that where I need look for it?
  • PHILIP RUSSELL Nov 06, 2012
    You should open the door and see a tag on the door or in the area the door closes into on front of machine.
    Debby GreenMitchel Nov 07, 2012
    Hey THANKS for getting back with me. Is what I thought too, when I open the door there are basic instructions on the tag, an 80 num to call and then what says p/n (the one I listed) that seemed to be wrong. that is the only list of numbers I can seem to find. Are none other elsewhere.
  • 36 Answers
THAT IS WRONG MODEL NUMBER THERE IS MORE NUMBERS..
When you get correct model go to searspartsdirect.com and you can order yourself.
Posted on Nov 04, 2012
SOURCE: dishwasher door will not open.tried
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Posted on May 30, 2009
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Posted on Nov 02, 2008
SOURCE: Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Posted on Oct 17, 2009
SOURCE: Amana Dishwasher door will not open. Latch you grap is very loose
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Posted on Mar 04, 2010
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
Door won't latch
replace door latch ***'y
Dec 10, 2013 | Kenmore 15762 Dishwasher
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
I just purchased a Kenmore dishwasher model 665.1303 and the door will not close. It seems like the mechinism on the door is locked not allowing the latch on the dishwasher to ingage in the lock on the...
Yes, that can happen. That latch is like the latch on your car door. You can trigger it, and then you can't close the door. But on your car, you can reset the latch by pulling the handle; your dishwasher doesn't have a handle, But you might be able to get a thin screwdriver in the latch and pry it back open. But I have found that once this happens, it tends to happen again. The best thing to do is replace the latch. If it's still under warranty, call Sears and arrange for them to send out a service man to fix it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 25, 2012 | Kenmore Dishwashers
We have a one drawer type dishwasher in our new motorhome and no pamplet seems to be enclosed. Could you please tell me how to lock it!! I does come pen when traveling! thank you.
Most dishwashers either have a latch located at the top that you must slide to the right, or have a mechanism that should lock it anytime the door is closed. Look at the top of the dishwasher door, if it's just a handle then it has the mechanism. Look at the handle for the door. There should be a lever within the handle that disengages the latch. There could be something broken within the door mechanism. You should see the catch on top of the door and receiver on the underside of the top portion of the dishwasher housing.
Jul 03, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Latch on my Kenmore dishwasher model# 363.14582100 won't close
Sharon,
The "latch keeper" has gotten out of alignment. You'll need to adjust it.
All you'll need is a phillips screwdriver to fix this. Open the door and look at the "latch keeper" (it's not on the door, but on the frame). It's the thing that the door lock/latch grabs on to when you try to lock the door. There are 2 screws holding it in place. Loosen these, pull the keeper toward you a bit and tighten the screws to lock it in. Now try your door.
This may take several attempts to get it just right, because you want the door closing tight enough so as not to allow a water leak and loose enough for you to close it easily.
If you have any questions, post back and I'll try to explain in better detail.
SG
Apr 01, 2009 | Kenmore Dishwashers
Dishwasher latch
hi there,
check the door latch and door handle to make sure that there is nothing broken or bent. otherwise, you have to replace the door locking mechanism.
Apr 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Door handle broke
.with a little luck you can try jiggling it for a while youmight get it ot pop open, if not youll needs to remove it from under counter. its held under countertop by 2 phillips screws (dropping the adjustmendt legs under unit will give you additional clearance to acess the screw head. after sliding d/w foward only 3 or three inches you gain acesss to the strike plate thats locking your latch. youll need to replace door latch and/or handle.
Feb 24, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Dishwashers Logo
471 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
