Question about Baumatic Ovens
My b550 keeps showing a fault code f3e3, what does this mean?
Error code F3E3 on whirpool self cleaning oven Shut off oven Now only broiler will work. Why
The fault code F3E3 requires replacement of the oven temperature sensor. I suggest you contact www.repairclinic.com for help with repair instructions and the part you need.
Apr 19, 2017 | Ovens
What does FO code indicate?.
I showed you what it means before. Did you follow the links?
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced http://products.geappliances.com/appliance/gea-support-search-content?contentId=16238
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). http://www.appliancepartspros.com/repair-help/dacor-fault-codes.html
Dec 03, 2015 | GE Ovens
Error code f3e3
Swap the leads on the probe jack terminals at the main board
Sep 27, 2014 | KitchenAid KEBS109BSS 30" Single Wall Oven...
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
My oven has an error displaying F3E3
F3-E3 Cleaning Temp over heat. Replace Sensor
Typical sensor:
Sensor location is usually here:
Whirlpool oven service manual
Jul 21, 2011 | Whirlpool Ovens
I have an F7 code on my gas range that keeps beeping
F7 code usually means a stuck key on the key pad. Some of the keys can be unstuck, but if high heat caused the pad to warp it might not be repairable.
  • Turn off power
  • Disconnect the key pad from the clock
    • If code goes away key pad is at fault
    • If it does not the EOC (electronic control board) is at fault
You can try giving the oven a hard reset by disconnecting the power for 20-30 minutes, then restoring the power.
Apr 17, 2011 | Maytag Ovens
Electric oven displays F3E3 and beeps
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 04, 2010 | Ovens
My oven codes F3E3.
Oven temp sensor failed. It's in the top left corner in the oven. If you have amultitestr you can test it. At room temp the resistance should be somewhere around 1000-1200
Jan 14, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
We have as ge oven and it keeps beeping and showing F1, what is the problem
This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 17, 2009 | GE Ovens
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Ovens Logo
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
