Question about Goodman Heating & Cooling
Goodman GMP100-3 home furnace status lite is constant red
Goodman GMP100-3 little blower wheel comes on but no ignition at all
Therinnaiguy
  • 1420 Answers
SOURCE: lock out on a goodman furnace
I have attached a link to download your owners manual troubleshooting guide. There is suggestions to follow coorisponding with the error codes.
http://www.dnmech.com/lit/IO-242.pdf
Posted on Nov 02, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Posted on Dec 05, 2007
SOURCE: goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Posted on Dec 13, 2007
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Posted on Feb 01, 2009
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Goodman gmp100-3 furnace The furnace will not start when I turn power on. It will hum but no click. The status light is solid red. Could the ignitor be bad? And what color should it be?
You should hear the ignitor pop. If you don't hear that pop sound, then the igniter is bad. They are easy to change, just make sure you turn the gas off and the pit-cock into the appliance and take a photo of exactly where the igniter tip is oriented so you can put the new one in the same spacing to have it ignite properly. The status light should be green when the furnace is 'On.'
May 09, 2015 | Goodman Heating & Cooling
I have a goodman furnace that give a rattle and vibration noise througt the vents in the house when the furnace comes on
Check the main blower. Make sure there is no debris stuck in the fan wheel( squirrel cage) or the blower as this can cause the blower to be out of balance and vibrate. Also check the blower wheel for any up and down or sidevto side movement which could indicate a worn motor bearing. Hope this helps.
Dec 24, 2013 | Goodman GMS90703BXA Heater
check continuity of hot surface igniter....open loop means replace igniter
Nov 04, 2012 | Goodman Heating & Cooling
Furnace starts up blower starts..nothing ignites...then shuts down. repeats and doesnt stop...sanded igniter stick and nothing happend. flashes red once.
Do you see the actual ignitor glow? You must be saying that you sanded the sensor. The ignitor, after the little inducer fan comes on will begin to glow a bright orange until the burner lights. If the ignitor is broken, you will NOT see a glow, and you may smell a faint smell of gas.
Apr 14, 2011 | Goodman GMS90703BXA Heater
Goodman furnace, inducer blower comes on, but surface igniter does not turn red, then kind of goes thru a cycle then igniter gets red burners light and then go out for no reason. Blower motor comes on @...
In the burner compartment opposite of the ignitor is the flame sensor. seems to be dirty. one screw holds it in. Remove and clean with a wire brush.
Nov 21, 2009 | Goodman GMS90703BXA Heater
Dec 05, 2007 | Goodman GMS90703BXA Heater
Goodman ac/gas furnace unit mdl. # gmp075-4
Nov 27, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
