Question about Refrigerators
Ge side by side freezer does not freeze at top refridgerator freezes at bottom
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number? Check the damper in the refrigerator.
Posted on Nov 05, 2012
  • 183 Answers
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
fridgetech
  • 473 Answers
SOURCE: Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Posted on Sep 28, 2008
  • 531 Answers
SOURCE: GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Posted on Apr 07, 2009
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
Ge BOTTOM FREEZER REFRIDGERATOR FREEZING UP. Turned down temp but will freeze everything in top compartment
Most likely to be a leak or the door seal, give it a good clean spray with silicone and wipe again.
May 24, 2017 | GE Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
I have a GE Profile Bottom Freezer Refridgerator. Everything I put in the fridge freezes. When I increase the temperature, it stays low.
Make sure you do not have items blocking air flow to the temperture sensor at the top left side of the refrigerator. Another thing to check would be air leakage at the air duct at the bottom back of the fresh foods section. Also, at that air duct, make sure there is an electrically activated dampener door inside (I've seen them missing), and that the damper door is not broken.
Mar 14, 2011 | GE Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
