Question about Refrigerators
Whirlpool model EV17ONYLSOO JO R134a freezer specifications
Where is the drain located on Frigidaire model r134a? is it the hole on the bottom freezer side?
R134A is not the model number. This is located inside the freezer on a white sticker on the left or right wall. Anyways, the drain is going to be located inside, behind the back wall of the freezer on the floor, directly below the Evaporator coils where all of the "cold" in your entire box is created. If you're referring to a refrigerator, there should be an aluminum tray/pan that all the defrost water drains down into. Sometimes they just freeze over & the hole becomes plugged w/ice. Hope this helps. Tips appreciated. Have a great weekend :)
Mr. All-Star
Jul 30, 2016 | Frigidaire Refrigerators
Upright whirlpool freezer is not freezing. fan motor comes on, light comes on but is not getting cold. how can I trouble shoot the problem?
Could be the cold control thermostat that is the problem. You didn't provide your model number so couldn't get specific here. I did find another forum thread that might give you more clues: http://www.applianceblog.com/mainforums/threads/36458-Whirlpool-freezer-cold-but-not-freezing
Sep 18, 2014 | Freezers
Add r134a refrigerator
it could be the fan not working or the defrost not happening. Open the back panel inside the freezer and see if the fan is operating
Oct 29, 2013 | Whirlpool Refrigerators
Need replacement R12 refer and freezer compressors. OEM Americold compressors no longer available. URS 48 DT model should also work. Thank you.
You can use R134a compressors with the Poly oil in them and use R12 or R134a (flush the remaining old mineral oil out of the system first). Match your BTU requirements.
Dec 30, 2009 | Refrigerators
Kenmore upright freezer coil leak find fix?
yes,have him put in some tracer dye in the r134a refrigerant and you will find it quickly if its leaking as bad as you say
Nov 18, 2009 | Dryers
Model R134a Refrigerator...Freezer works fine but no cooling in the refrigerator... What can I do if anything besides replace it?
Two things, One, the coil in the freezer could be Iced up, deforst the freezer.
Two, the circulatng fan is not running.
Sep 01, 2009 | Frigidaire Refrigerators
Refrigerant gas used in Kenmore freezer
Hi: You didn't give me the complete model number. Not to worry though. Look at the model number tag of the freezer. If it's a newer model it will use R134A coolant. The tag will tell you the amount of refrigerant and the type. I hope this helps, Jeff.
Jun 09, 2009 | Kenmore 64802 Top Freezer Refrigerator
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Adding R134a
You have to go on the high pressure side. It means that it would be better to put a acces valve on before the dryer. The 134A needs to be charge liquid to make sure that the bottle is upside down. Hope it was helpful. :)
Francois
Aug 11, 2008 | Whirlpool Freezers
Info question, RAM
Well this question is too vague! I need to know specific Model of your PC is it 2560, 2570? What is the model Number as this is very important when doing an upgrade of any kind to any type of PC! I have an answer just need specific model!
Nov 27, 2007 | Computers & Internet
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
