Question about GE Spacemaker (74290) Clock Radio
Power button on Spacemaker radio 7-4212B doesn't always work
Depressing power button doesn't always make contact
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: We have a GE Model JVM1339WW002 XL Spacemaker started to make louder buzing noise when turned on & doesn't heat
Suspect inverter (power) and or the Magnatron---neither are cheap parts.
Posted on Oct 17, 2012
Door latch problem - doesn't always respond well
You will have to take the unit apart and see the reason. Could be a warn button or a bent part.
Dec 31, 2012 | GE Profile PEM31DMBB Black 1-cu-ft...
It was working fine. Then stopped. When you depress the pedal the motor idles but the needle doesn't go up and down
it's possible that the foot pedal has gone out
check to make sure the power cord in inserted into the machine correctly & also the foot pedal
Apr 02, 2012 | Sewing Machines
X1000 power button
The power button on these laptops is easily depressed underneath the power button strip especially when the switch becomes dirty, the screen doesn't light up, and the user gets frustrated. When I find a depressed button, I take the keyboard off by removing the 2 13mm screws with the keyboard emblem from the bottom and moving the 4 tiny plates between the esc-F1, F4-F5, F8-F9, & F12-delete keys. The power strip is then removed by gently prying up near the CPU and pulling it up and toward the front of the laptop. You can then either repair or replace the button or strip. I small drop of contact cleaner down into the switch will help it function reliably. Even a small drop of rubbing alcohol will sometimes work but contact cleaner is the best.
Mar 02, 2012 | Compaq Presario X1000 Notebook
2001 dodge stratus Radio doesn't work bass & trebble lights blink always
you should let it recheck from a electrician, probably one of your wires loose or something burned on the first i could think
Feb 06, 2012 | Cars & Trucks
My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Feb 05, 2012 | Saws
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
I am not getting any picture from the tv. dvd and radio is working fine.
press the AV button on the remote control & if it doesn't work, look for the TV button on the remote control; & if it doesn't work again, check the booklet that comes w/ the tv upon purchasing it or bring your tv to where you bought it & make use of the guaranty voucher for them to fix it for free, (try those buttons first before bringing it back to the store).
May 12, 2011 | Televison & Video
Can't turn it off
sounds like the power button rubber has degraded . please dismantle the radio and clean the button contacts with mild solvent. use nail polish remover to accitone. Don't use soapy water.
Sep 01, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
GE Spacemaker (74290) Clock Radio Logo
47 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
