Question about HP Pavilion a1114n Athlon 3400+/1GB/160GB/DV+/-R/RW/XPH (PX748AA) PC Desktop
I have a problem with a HP Pavillion a1114n. when u press the power button the cpu fan spins up for about 1 second and then cuts off and then the power led blinks on and off continuously
Lots of dust and dirt inside case. Tried cleaning, but it did not help.
  • HP Master
  • 5,660 Answers
Bad Power Supply.
Weak voltage power rail
The hardware components inside your computer (HP Pavilion a1114n Desktop PC), are cooled by air flow. Heat is radiated away, then air flow helps carry the heat away. (Heatsink/Fan)
The Power Supply is cooled by the same method.
Power Supply's used in today's computers are SMPS.
Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Click on the photo of the open Power Supply, to the upper right.
In-between the letters B and C, and C and D; are Heatsinks.
Look like whitish/grayish rectangular blocks, of varying thicknesses, stacked along a singular flat bar.
The block shapes are aluminum fins.
Whatever this Heatsink is placed against, it will absorb the heat from it, and radiate it away with the thin fins.
Air flow from the small internal Fan, helps carry heat away from the thin fins.
Heat = Wasted Energy
The Power Supply overheats, and cannot keep up with the call for power.
Components inside fail; the Power Supply fails.
A THIN coat of dust on the Heatsink fins for the Processor, will drop the cooling capacity a LOT.
If you would like to test the Power Supply, you will be using the test for the three main voltages;
3.3 Volts, 5 Volts, and 12 Volts. All are DC Voltage.
(In comparison two D cell flashlight batteries store 3 Volts DC.
The dangerous voltage is contained within the metal case, of the Power Supply)
You need a multimeter. An economical model is around $5 to $12.
Available in a multitude of stores. An auto parts store is but one example. Large store chains may carry them on a checkout aisle rack.
Or if there is a working unused computer, that has a KNOWN to be good, and Compatible Power Supply, you could borrow it for a temporary test unit.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=501964#bph06788_section_2
Regards,
joecoolvette
Posted on Nov 05, 2012
5 Suggested Answers
SOURCE: HP Compaq D530 sff Will not power up
I have the same problem but it seems to be related to the NIC. When I start without the ethernet cable plugged in it's fine, plug in the ethernet cable and the machine stops dead. I can't even start the PC with the cable plugged in.
Posted on Mar 05, 2008
  • 973 Answers
SOURCE: Trying to power up the unit
It sounds like either a bad Hard Drive or your Motherboard is shot. Is there anything showing up on the screen when the computer is trying to boot up?
Posted on Jul 22, 2010
  • 34 Answers
SOURCE: cannot get power to the tower. power led is
First check to see if you have any capicitors that are defective. (see attached image)mrtekhead.jpg
If you see any that look like this then the motherboard will need to be replaced.
If you do NOT see any, then unplug the power cord from the wall and let sit for 15 minutes to let the unit discharge. Check power outlets or power strips to make sure they have power too. Plug back in and check for power. Hope this helps.
Posted on Mar 06, 2011
kritiko
  • 107 Answers
SOURCE: Error on normal boot up,
HI ker7758 ,
You may need to apply "Thermal paste/grease " to the CPU.
You can watch this video tutorial from Youtube:
http://www.youtube.com/watch?v=o7rPqCvCt0g
There are different types of thermal grease. You don't have to buy the expensive ones. The cheapest on the market should be able to do the job.
Posted on Apr 09, 2011
Testimonial: "I found one of the hooks for my heat sink springs had broken off. I re-soldered. Will also take your advice & re-paste."
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
HP Pavillion dv4 turn on and the fan start for a second twice and then tunn off After around 5 seconds a few leds are blinking Hard Drive work fine on other laptop What can be the reason
Hello, that sounds a motherboard problem...
Try to do this first :
1- take the battery out and disconnect from power
2- press and hold the power button at least 10 seconds
then put only the power cable not the battery and try to boot...
If this dont help...your motherboard needs to be repaired or replaced.
Thanks.Please rate this answer
Jan 25, 2011 | HP Pavilion dv4-1120us Notebook
I WAS HAVING PROBLEMS WITH OVER HEATING, NOW MY LAPTOP HAS CUT OUT AND WONT RE-START. WHEN YOU PRESS THE POWER BUTTON IT LIGHTS UP AND YOU CAN HEAR THE FAN OR SOMETHING BUT THE SCREEN STAYS BLANK. ALSO...
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
My hp pavillion dv4-1220us laptop, won't start up...I press the power button and it turns on for a couple seconds and then turns back off....
1) Is it the battery, power up using the power supply.
2) When the power supply is plugged in, is there a charge light/led (could by a bad power supply not charging or providing a good connection)
3) Is the CPU over heating? Check the vents underneath are they clogged with dust?
After this, you're getting into internal faulty component issues and need someone to look at it.
Apr 13, 2010 | HP NB199UA Pavilion Notebook
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
My 754n will not turn on
Make sure that the power wolts is as per required.
and try connecting to different wall outlet and also check the CPU fan. if it is firmly fixed.
Jan 19, 2009 | HP Pavilion 754n PC Desktop
HP Pavilion a1114n Athlon 3400+/1GB/160GB/DV+/-R/RW/XPH (PX748AA) PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
