Question about Casio LA670WA-1 Wrist Watch
How do i fix the time on my watch - Casio LA670WA-1 Wrist Watch
I just purchased a stainless steel women's 26284 wrist watch. I set the time when I received the watch and it will not keep time
If the watch is running to slow or fast the problem is in the timing module where the quartz crystal is located, there is nothing that can be done to adjust this to fix it. The watch should returned to the jewelers.
Feb 14, 2011 | Lucien Piccard 26024 Wrist Watch
I would like to have my son's watch repaired. I think it's a Timex but not sure. I see the word "Expedition" on the front case and a large E on the back. Some smaller letters that look like...
Just about any watch shop should be able to fix your watch, no need to go anywhere special, but if you need a place to mail too.  Here are a couple of choices for you.
Citizen Watch Repair
Dallas Service Center
800 E. Campbell Road
Suite 371
Richardson, TX 75081
(972) 234-4900(tel)
(972) 234-4901(fax)
Time-Tec Watch Svc
635 S. Hill Street
Suite 209
Los Angeles, CA 90014
(213) 488-9222 (tel)
(213) 488-9221(fax)
(888) 448-TIME (toll free)
www.Time-Tec.com
Eastside Watch Repair
E.S.W
P.O Box 8004
Mill Creek,WA 98082
(425) 641-7978
Nov 18, 2010 | Timex Watches
Ots sport watch setting instructions ???
My watch is OTS T6320G ,kindly advise as I want to fix time and date
Apr 14, 2010 | Bulova Watch
How to fix THE TIME??
You need a city that is either north or south of Saudi.
Does Moscow feature in your city list?
Jan 18, 2010 | Garmin Forerunner 405 GPS Watch
I have a Luminox Navy Seal Watch. It has worked fine for about 6 or 7 years. I noticed that the minute hand seems to stick and then release about 4 seconds at a time. Is this something that needs to be...
Obviously you never noticed this before. Do nothing, as there is nothing to fix. This is normal behaviour sooner or later noticeable on all quartz watches.
Rate me, plz.
Jan 11, 2010 | Watches
Replace a battery cover in a guess watch
Your watch case back (battery cover) actually lost it shape some how that's why it's not closing, it's need alignment,
which take lots of time try expert watchmaker hope you get it fix.
even thought it fix some time it's lost capability to keep your watch save from water.
hope this info help
From
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Oct 01, 2009 | Guess G85675G WristwWatch
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
I have a DKNY OLED watch, but when I press the button for the time, it keeps resetting itself (both time and date) and no matter how many times I reset the time, it keeps resetting itself. How can I fix...
It sounds like your watch is not coming out of set mode. Make sure that when you are done setting the watch that the display is no longer flashing. This is usually done by holding down the mode or reset button.
If this is not the case then have the watch AC'd. As long as there is no problem with the circuit board this should fix the problem.
Sep 21, 2009 | DKNY Watches
My watch the bezel that you change the time / date with, when pulled out comes all the way out, can not change time. Watch less than a year old, can not find the warrenty, not the end of the world, do not...
There are two possible causes: settting lever in your watch is broke/out of engagement or stem is broke. Not a big deal, but watchmakers skills are needed to fix it, as watch must be dismantled.
Any decent watchmaker can do it, so, just find your nearest watch repair shop and ask to fix it. Prices may vary, but no more than 25% of the cost of watch itself.
P.S. It is called Crown or Winding Crown (you say bezel).
Rate me, please.
Aug 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Need an Instruction Manual for a Accurist Watch MB7 37N, can you
how can i fix the time please help me... i have a watches accurist mb680...and i don't know how to fix the time.thank you verry much.
Dec 14, 2008 | Bulova Watch
Casio LA670WA-1 Wrist Watch Logo
20 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
