Question about Toys
Removing rear axle on john deere gator 620i - Toys
momsjustknow
  • 135 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 19 Answers
SOURCE: Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Posted on Apr 21, 2009
mowerman1857
  • 389 Answers
SOURCE: does a 1970 john deer 140 have a comeplte axle in
They have a right and left axle shaft that meet in a differential. If it had a solid one piece axle it would be impossible to steer. When making a turn, one rear wheel must turn slower than the other to make the arch.
If you would like to get a picture that better shows it, you can go to johndeereparts.com and open up the parts catalog, type in your model number and locate the transmission view in the sectional index
Posted on Oct 29, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 1340 Answers
SOURCE: remove and repair rear axle seal on a john deere
This is not related but...I saw that I forgot to paste the link to Howse.I take it you found it okay?Thanks and good luck.Greg
Posted on Aug 09, 2010
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
Jul 27, 2016 | John Deere 2010 Gator XUV 4x4 620i
How do I fix john deere 620I gator steering assembly
then why do you not look for the bent rod and unbend it or replace it .
May 26, 2016 | John Deere 2010 Gator XUV 4x4 620i
How to replace the tires on a Deere Gator
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels and axle
4. remove the red pin at the front of the dump bed
5. remove the two black pins at the rear of the dump bed
6. remove the dump bed
7. lift the green plastic cover off
8. remove the two screws that hold the gearbox and motor to the body
9. remove the gearbox and motor assembly
10. remove the two screws that hold the motor to the gearbox
Nov 29, 2012 | Peg Perego John Deere Gator HPX Ride on...
How to remove the bolts on the starter John Deere Gator 620i
This is what I did to remove starter on 620i xuv gator. Remove starter solenoid and use extension 3/8 drive with universal joint to remove top bolt or remove front half of plastic shroud over drive belt assy , drill hole into cover in line with top starter bolt, insert extension with socket onto top starter bolt. Be sure to cover drilled hole with suitable material.
Jun 30, 2012 | John Toys
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
How do we replace the rear wheels on the John Deere Gator?
remove the center cap then bend the metal push nut with a needle nose pliers and pull it off then pull the wheels off leaving the axle in place
Jun 07, 2010 | Peg Perego John Deere Gator HPX
John Deere Gator HPX 12 Volt Ride on Toy by: Can anyone tell me how to get the tires off of a j...
May 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Please let me know how I can change the rear tires of the John Deere Gator HPX 12 Volt Ride Toy
I want to add additional traction to my John Deere electric Gator. I have heard that you can somehow slip a bicycle tire over the plastic tires. Has anyone done this and how do you do it?
Sep 06, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
200 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
