Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
4 1024mb 1066 ddr2 only running at 667
Saw in the manual it only recognizes 1066 in the black slots. so if the 1066 is in the other slots does it down grade all of the memory to 667. if so can i over clock them or do i need to get rid of the 4 sticks and buy 2? is it faster if i get rid of 2 sticks at get the 1066 or keep the 4 and only run at 667? any suggestions appreciated.
  • bill callison
    bill callison Jan 05, 2009
    i dont have any 667 anywhere nore would i buy them. guess you dont know the asus P5QC mother board. wasnt going to try to over clock until i get my cpu cooler.
    ASUS P5QC motherboard
    INTEL Q8200 CPU
    4 OCZ 1024 at 1066mhz
    silencer 750w
    blueray dvd
    light scribe dvd
    pny 9800gt
    24" sceptre 1920x1200
  • bill callison
    bill callison Jan 06, 2009
    thanks. i been looking and reading reviews of 2gb sticks. lol. and also looking for new motherboard. lol. but it was first out of 4 motherboards that i bought from microcenter that worked. and they were suppose to be all new but i think i got took on the other ones. because all the parts werent in the box on 2 of them
    President:
  • 846 Answers
Yes if all the sticks of ram are not the same it will downgrade the faster sticks to match.
1.Buy two sticks to match the faster ones
2.Id run 4 at 667 personally, if you multitask it might be best.
Posted on Jan 04, 2009
  • Quickfx PC Repair Jan 05, 2009
    Yes you can only install memory that is 1066 mhz in the black slots (which is very odd that only two channels support it)
    If you use 4 sticks the two channels that don't support 1066 cannot be overclocked, and the two sticks in the black slots will be downgraded to match the memory in the yellow and orange slots.
    You can basically use just the two sticks in the black slots, and they will run at 1066mhz..
    You can sell all your memory and buy (2) 2 GB sticks and use just the black channels.
    Keep the memory you have and let it run at a lower clock speed.
Asrock g31 m motherboard will only post if only one ram slot occupied , will not post if both slots are used , identical matched pair of ram ddr 667 800 mhz crucial ballistix both tested in another ri
I did some research. You didn't say what density the RAM was, but everything I can find on the Ballistix 800 MHZ DDR2 states that it runs at 2.2V. The standard for DDR2 RAM is 1.8V. You motherboard has both and AUTO and manual setting capability for memory (DRAM) voltage. It is possible that the AUTOP feature is not detecting the need for 2.2V, and that with only one DIMM installled, the memory marginally functions, but with the extra loading of the second it will not. Boot the system with the single DIMM, go to the BIOS, and set the DRAM voltage manually to the 2.01V setting (Verify by the part number of the RAM with the CRUCIAL website that is uses 2.2V before doing this). Once you have changed the voltage in BIOS, shut down and add the second DIMM and see if things improve.
Jan 16, 2012 | Asrock G31M-S Motherboard
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
My asus m3n78-em motherboard does not boots with 6 gb ddr2(3 chips of 2 gb) ram it works properly with 4 gb ram(2 chips of 2 gb) i dont know what to do it used to work properly before but its not working...
This board has a dual channel memory. To function correctly both channels must be identical otherwise , as you can witness, it chokes. To put it simply you must put either 2 identical sticks of memory or 4 - it can't run on 3.
Jun 16, 2010 | Computers & Internet
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
I was upgrading the memory to 4gig and was told to do a BIOS update from Toshiba. After the update I noticed it was running slow. Soon, it wouldn't start, you could only get to the "repair" screen, but it...
Hi, here is the specs of ur laptop memory, there is a possibility that the memory that u purchase is not compatible with ur laptop specs.. I hope this will help u..
Memory
Configured with 1024MB PC5300 DDR2 SDRAM (both memory slots may be occupied). Maximum capacity 4096MB,
Memory Upgrade
Part Number Description
PA3512U-1M1G Toshiba 1GB DDR2-667 Memory Module
PA3513U-1M2G Toshiba 2GB DDR2-667 Memory Module
Aug 13, 2009 | Toshiba Satellite A215-S7422 Notebook
Cant pick both RAM same time
hopefully you inserted two similiar 1 GB RAM memory devices by the same manufacturer into the right slots 1
you may have a board that:
- has four slots available (two + two)
- but supports only a maximum of 1GB (two similiar 512mb devices)
or
-supports only a max of 2 GB of the same kind and same manufacturer,
so inserting all u got and hoping the PC does the memory management might not work!
please see the mainboard manual (if u have one) or download it from the manufacturer's site.
Jun 18, 2009 | Computers & Internet
DDR3 RAM
According to your description you have 4 memory slots and each memory slot can hold
DDR2 PC2-6400
DDR2 PC2-8500
DDR2 PC2-5300 with a maximum of 2GB per slot.
This board does not support DDR3.
I hope this helps your memory question.
May 01, 2009 | Acer Computers & Internet
RAM Memory Speed compatibility
all memory will operate at the slowest speed chip unfortunately. the only way to get the higher speed is to have all chips capeable of that particular speed.
Feb 14, 2009 | ASUS Computers & Internet
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
179 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
