Question about Tools & Hardware - Others
When the blower motor starts it makes a noise for a minute then stops making the noise but does keep running
  • 3 Answers
Check the capacitor, it could be weak. If you have a weak capacitor it may have a hard time starting the motor all the time. Most capacitors should have a rating of + - 5% of actual rating on the label.
Posted on Nov 08, 2012
My Rheem Criterion II gas furnace makes metal slapping noise when the blower comes on. It is not the blower or the motor.
Is there noise when the inducer motor comes on? The small motor that comes on first. It sucks the co out of the combustion chamber. It comes on first. Then the burner lights then the blower comes on. And the noise continues while it's running and doesn't stop till the blower stops? Is that correct? But it's not the blower wheel? Could it be out of balance and hitting the blower shroud?
Feb 18, 2017 | Heating & Cooling
Why won't my carrier furnace come back on?model number 58rav095.It was running and heating,but makes a horrible noise on start up.Is it the motor going out?
If the noise is coming from the fan coil unit then it could be the blower motor. If the bearings are failing it will make noise on start up and run. But after a period of time it will overheat and the overload protection switch will lock it out to keep it from running until it cools down.
Mar 10, 2015 | Carrier Heating & Cooling
Heat wont work in my saturn
Your cars blower motor is probably shot from moisture and you should check the resistor also as it runs all the speed functions of the blower motor regards Chris
Jan 24, 2013 | 2001 Saturn SL
Rear blower fan making a knocking noise when running
This may be a defective blower motor shaft bearing , have a technician listen to it to confirm the problem is the bearing in the motor.
Sep 05, 2012 | 2003 GMC Envoy
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Apr 22, 2010 | Kenmore 62602 Electric Dryer
HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Tools & Hardware - Others Logo
75 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
