Question about Ricoh Office Equipment & Supplies
Error code sc520
Define and clear error
  • 3 Answers
Joel, here is a link to check out: http://copierliquidationcenter.com/Copier_University/index.php?topic=988.0 Hope it's the paper jam issue. I doubt a wire has worked loose, but possible if the printer moves a lot while printing. If it is the part issue, my guess is another printer purchase would be the wiser move.
Posted on Nov 04, 2012
On my casio fx-83GT PLUS calculator whenever i use the inverse cos,sine and tan function math ERROR comes up how do i fix this
The inverse cosine function is defined for arguments from -1 to +1. 6 is outside of this domain, thus the error. Do you get an error if you try the inverse cosine of 0.6, for example?
If you're getting the same error for the inverse tangent, could you post an example?
May 12, 2014 | Casio FX83ES Scientific Calculator
How can i solve : 49.2f9d service error
On your PC, clear the print queue. Power the printer on and see if the error reappears. If no, there was a corrupted print job in the queue.
Power off printer, unplug the network cable, power on and see if error reappears. If yes, upgrade the firmware
Feb 26, 2014 | HP LaserJet 2420 Printer
Service code sc520
Paper tray error.Try reset by open/close the front door,if not reseting enter in the service mode :press mode(yellow)key-107-Clear/Stop(red)key (keep pressed more 3 seconds) enter in SP mode,open the front door and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 27, 2013 | Ricoh MPC3500
WWW.JANDY-DOWNLOADS.COM
Make sure all the dust is off the fan definately and all other parts are cleaned.Leave unplugged for a few hours if you do not have a reset option to clear the error code
Jun 03, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
I am trying to graph any possible equation and I get undefiend varialbe for any kind of equation as simple as x=7. It will always show as undefiend varialbe for any equation. I don't know why it does this.
Undefined variable error message displays when you evaluate a user-defined
function or run a user-defined program that references a local variable that is not
initialized (assigned a value). You have to type LineVert 7 and then graph function x=7. See captured image
May 02, 2011 | Texas Instruments TI-89 Calculator
Were is the reset button
There is no reset button. In order to reset phone, you can perform following steps.
Steps to perform Master Reset
Performing this function will reset all user-defined settings on the device.
  1. From the standby screen, tap the Menu icon > Settings > More > Reset Settings > Master Reset.
  2. Tap Yes after reading the warning.
  3. Enter Security code, tap OK. The default security code is 0000.
Steps to perform Master Clear
This will erase all data (pictures,address book,any downloaded content) and reset any user defined settings on the device.
  1. From the standby screen, tap the Menu icon> Settings> More> Reset Settings > Master Clear.
  2. Scroll to and select Handset.
  3. Tap Yes after reading the warning.
  4. Enter Security code, tap OK. The default security code is 0000.
Mar 30, 2011 | LG Vu CU920 Cellular Phone
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Error code oxcoooooe9 what does it mean
tech_details.gifAn executive worker thread is being terminated without having gone through the worker thread rundown code, which is not allowed.
After the Stop code will be 4 hex values: {Parameter 1, Parameter 2, Parameter 3, Parameter 4}.
Parameter 1 specifies the exiting ETHREAD (the ETHREAD structure is an opaque structure that serves as the thread object for a thread).
Parameter 2 is not defined.
Parameter 3 is not defined.
Parameter 4 is not defined.
Have you recently installed a new device or software? If so, system restore might fix you up. This site will show you how to determine what specific module caused the problem. It is somewhat complex but just follow the instructions.
http://thelazyadmin.com/blogs/thelazyadmin/archive/2006/05/23/Debugging-STOP-Errors-With-WinDBG.aspx
Aug 05, 2010 | Toshiba Satellite L305-S5908 Notebook
136 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
