Question about Refrigerators
Ge side by side refrigerator GSS25XSRDSS freezer not freezing
My ge side by side refrigerator GSS25XSRDSS freezer not freezing sometime it works well and sometimes is does not. What can be wrong. Ref is 7 years old.
  • 4 more comments
  • Josefina Harmon Dec 03, 2012
    Dear Richard, I wrote about my GE 25.4 Cu. Ft. Stainless Side-by-Side Refrigerator with Dispenser GSS25XSRSS before. It was not cooling in the freezer and ice cream melted. I unplug it for a little while and then pluged it in again and it started to run fine and cool in the freezer and other side. But It goes thru the same routine every few weeks it stops cooling and things melt. So I unplug it again and replugged it after a few minute and it starts to work again. It is driving me crazy.
    I don't know what is wrong with it or what it is that I need to repair. Please help me. It is only 7 years old and I keep looking new.
    Like today it is working but I notice a thin frost inside the freezer. I broke down yesterday and I unplugged it and replugged it again and it started to work.
  • Richard Roth
    Richard Roth Dec 03, 2012
    OK, it has got to be a sticky relay on the main control board. Replace the board and it should be fixed. Here is the board to order.http://bit.ly/TpI8Jy
  • Josefina Harmon Jan 28, 2013
    Hi Richard Could you tell me what could be the problem if the Ref is freezing the fresh food compartment. We have change several part on it and now it is doing this.
  • Richard Roth
    Richard Roth Jan 28, 2013
    If the refrigerator is freezing up you probably have a bad damper that is stuck open allowing cold air to constantly flow into the refrigerator side. Here is the part to order.http://bit.ly/X4vUqb
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Nov 05, 2012
catriver
  • 878 Answers
SOURCE: GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Posted on Apr 04, 2007
fridgetech
  • 473 Answers
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Posted on Oct 11, 2007
  • 1314 Answers
SOURCE: Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Posted on Feb 13, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | GE Refrigerators
My ref is not cooling, sometimes its cold sometimes its not. but the freezer works ok.
heatman101
Sep 04, 2011 | GE Refrigerators
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
FREEZER AND REFRIGERATOR NO LONGER COOLING (GE MODEL GSS25XSRDSS)
Not enough info. If the unit is totally dead then I would suspect the main board (in the rear under a panel) if the fans are running I would suspect the compressor is not running.
Oct 16, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
I have a GE side by side refrigerator about 7 years old it has a thru the door ice/water dispenser the water seems to be dropping in the ice tray inside the freezer and freezing in a mass at the bottom of...
Your inlet valve is malfunctioning. Sometimes when they go bad they either let in to much water or none at all. It is located on the back under accesss panel where your water line connects to your fridge. Rate me if I helped you!
Aug 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is cold but not freezing the ref is not cold
Simple! Refrigerent leak only results in poor cooling. Check your thermostate also to make double sure of the cause.
Jul 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer dos not Freeze and Regular side is not cold
It is possible that the freezer side is iced up due to a fanmotor not working. Check. If the fanmotor is working, then there may be a fault with the defrost system which is controlled by a main pc board and may need to be replaced.
May 13, 2009 | Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
348 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
