Question about Refrigerators
GE GSS25XSRD SS - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 05, 2012
5 Suggested Answers
aasc
  • 1606 Answers
SOURCE: GE GSS25Xsrd ss-the ice maker
The problem is the main control board behind the 8 X 10 panel behind the refrig . When you say the " motherboard " , are you refering to the main control board , or the board on the freezer door ? If the board behind the refrig is the one you are refering to , then possibly you can replace it again under warranty .
Posted on Aug 15, 2010
heatman101
  • 43501 Answers
SOURCE: gss25xsrd ss GE fridge gets
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 26, 2010
  • 441 Answers
SOURCE: No chilled water from door. Isn't there a heater
You can order it from Marcone.com with your model number. The part will be called "heater kit"
Posted on Jan 03, 2011
  • 2122 Answers
SOURCE: Frig too warm on top, too cold on bottom
inside the fridge section you have a fan damper assy.if you go here you can see it
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
part number WR49X10091,the cold air comes through the damper and the fan in it blows the cold around into the fridge section,warm air rises so this is why it's warm on top and colder on the bottom.i just installed this part for a customer,unplug the machine or shut it down,remove the 4 screws that hold the top light assy. on drop it down,unplug the wire harness,pop off the cover to the water filter,remove the top two shelves then pop off the middle cover on the back wall,this allows you to remove the two screws that are behind it,remove all screws and remove the damper fan assy.look at the instructions,the one i worked on i had to remove the gasket that's on the freezer wall side and replace it with the fat gasket in the box and then put it back together again,it took me around 35 minutes to do the job.hope this helps you out
Posted on Aug 30, 2012
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Aug 30, 2012 | Refrigerators
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
heatman101
Dec 26, 2010 | Refrigerators
GE GSS25Xsrd ss-the ice maker is making ice but the water and ice dispenser is not operating. No lights. Nothing. Motherboard has been replaced about 6 months ago.
Aug 15, 2010 | Refrigerators
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
I purchased a GE SS 22.5 CF Refrig. The doors do
usualy there isnt a height adjustment most common problem is worn door cam due to over weighting door the door cam is made from hard plastic and is known to wear out even break
Mar 01, 2009 | LG LRFD25850 Stainless Steel French Door...
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE fridge and dishwasher
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
