Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I can't do format to my flash
  • SanDisk Master
  • 27,725 Answers
Click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps
Posted on Nov 05, 2012
My Sony Vaio SVE15129CAB can't read Sandisk USB flashes
Are all your Windows Updates Current, up-to-date? What is the file/data format on the flash drive? If you open the Computer folder is the Flash drive there? On other Laptops what opens the data on the Flash drive? The software? Do you have the same software?
Apr 04, 2013 | Computers & Internet
Help, my16GB SD Card can't be opened nor formatted but it can be read.
Since I was also facing the problem, where my SD card got corrupted and was not able to access. finally I came across the software to recover corrupted SD card which helped me to recover my lost photos and here is the download link
Dec 05, 2012 | Imation Electronics - Others
Losing memory capacity
Hi Sometimes if the files/data in your phone were hid by the virus, it will not show.So to clean up this the best way to get rid from this issue is to flash the phone.You can do it by contacting mobile repairing shop or flash the phone by yourself.But before you do this try to format it by press and hold *,3 ,green keys and power on the phone.Thanks for visiting fixya
Aug 12, 2012 | Nokia N95 Cellular Phone
How to solve the problem " please insert the disk into drive" of memory card
ok how did format get done? if not on computer then formatting needs to be done with card in computer and do a thorough format NOT quick format
May 26, 2012 | SanDisk 2GB microSD Memory Card
Samsung format sgh-790
Hello xanxi_uki, to "Format the Sandisk;
You can (right click), or 2x click to 'open' the "Computer" from the Desktop!
This will 'open' the Computer's Hard Disk Drives.
Or you can click on the "Start Button" and 'open' the "Computer."
Once you are in the Computer Drives; find the "USB Flash Drive."
Next, (right click) to 'open' the 'shortcut menu', choose to "Format."
In the Format UDisk (?), click on the "File System" [Drop down arrow "Box"].
Choose the [NTFS] from the list !
Select 'how much' of the USB Flash Drive you want to use?
This will be in the "Allocation unit size" box !
Now, you want to choose to {Quick Format} the USB Flash Drive.
"Place a [check] in the "Box" by clicking on it, to do so.
Next, click on the [Start] button."
The "formating" of the (USB Flash Drive) will begin.
Once it is 'finished'; use it as you like.
"If you need help with anything else?
"Write a 'comment'; I'll be on "Stand-by!"
If all goes well? Give a "Helpful Rating", thanks, paul7of9
Oct 02, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I have a transcend 4GB pendrive. it has become write protected due to virus. how can i format it. i have tried many processes but can't get my pendrive formatted.pls help
Some usb keys or flash drives have a little switch thatlocks it & makes it read only. Try looking for something like this. Or youtry following these steps:
For USBdrives:
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partitin you want to format (where the leter and is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select , file format, disk leter, label etc should be all right if youleave defaults.
7. click ok
This will recreat the partition and format it in proper way.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My 4 gb kingston pendrive show i/o device error and cant be formated,what can do noe
Try using another USB port, if still no good, go into Windows device manager, right click the USB drive & remove. Restart your PC & it will re-install the driver. ther than that, make sure it's fully plugged in.
Apr 27, 2011 | Electronics - Others
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
32 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
