I have a ge washer that needs a timer knob replaced but i cant get it off
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 05, 2012
  • 178 Answers
SOURCE: ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Posted on Mar 16, 2008
  • 958 Answers
SOURCE: Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Posted on Aug 02, 2008
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
SOURCE: timer replacement
the knob, actually, unscrews. pull out the knob as if you are starting a wash cycle, and use needle-nose pliers to hold the back, and unscrew. i learned the hard way when i pulled on it like it was one of the other knobs and yanked the post out.
Posted on Dec 02, 2008
  • 1214 Answers
SOURCE: kenmore washer 110.92292100..Washer Timer Control Knob is broken,
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Posted on Feb 03, 2009
Need directions on replacing the knob-Timer Assembly for the WSXH208V1WW. Bought the replacement part but can't find any instructions for removing and replacing it.
Remove top of washer then Remove timer knob then (2) screws behind knob, un- plug timer connector and replace of course always unplug machine First
Sep 27, 2010 | GE WSXH208A Front Load Washer
GE WASHER MODEL #WBSR3140G0WW: TEETH ON CONTROL
I suspect that a mounting tab has broken off the timer. Take the four torx head screws off the back edge of the top of the washer and open up the backsplash to confirm this. I manufacture a make shift Z shaped metal part to hold the timer in place without having to replace the timer.
Mar 25, 2010 | General Electric WBSR3140GWW Top Load...
How do I replace the "notch" (which is stripped) that is used to align the knob to the actual timer? This is on my GE Washer
It depends on which piece you are talking about. If you mean that the inside of the knob itself is stripped you just need to grab a new know off a similar machine or get a new one from a parts store (pretty cheap).
If you mean that the metal piece sticking out of the timer is stripped then you need a new timer since that piece cant be replaced individually. You can get a new one from an appliance parts store, just take them the model number of the machine and they can look it up and most likely tell you how to replace it as well.
Dec 13, 2009 | GE WDSR2080D Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
Timer Knob
The clip pulls straight up off the shaft directly behind the knob. You can use a small screwdriver or a pair of needlenose pliers to pull it out. Once the clip is removed the knob will slide off the timer shaft.
Apr 21, 2008 | GE WDSR2080D Top Load Washer
Ge timer on washer is broken
Mar 16, 2008 | GE WDSR2080D Top Load Washer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
