Question about Microtek 997M 19" Flat Panel LCD Monitor
I have connected my microtek lcd monitor to my dell laptop computer. the monitor is plugged into electric outlet. the green light on the front of the monitor blinks. and i get a report of "no signal" but the picture on the lap top does not come on. How do i get the standalone monitor to receive the lalp top picture?
    Problem Solver:
  • 7 Answers
Have you tried pluging in the monitor in to the laptop before even starting the computer or Putting the computer in to "Stand by" then pluging in the monitor and then bringing the laptop out of "Stand by" or yet when you do have the computer on with the monitor pluged in, try "Fn" and a button hat has like two screens on it with a small bar in between them? All these should work.
Posted on Jan 04, 2009
How do I replace sound bar on monitor?
Deb Powell,
Reverse the steps listed below. They are for connecting the sound bar.
1. Working from the rear of the monitor, attach the Soundbar aligning the two slots with the two tabs along the bottom rear of the monitor.
2. Slide the Soundbar to the left until it snaps into place.
3. Connect the Soundbar with the power brick.
4. Plug the power cables of the power brick into a nearby outlet.
5. Insert the lime-green mini stereo plug from the rear of the Soundbar into the computer's audio output jack.
NOTE: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only.
NOTICE: Do not use with any device other than Dell Soundbar.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2016 | Dell E197FP LCD Monitor
My microtek 710s monitor won't connect to my graphics card. So, the monitor is VGA and connects to an adapter which changes it to DVI , into my card. Except the monitor won't turn on. And it did yesterday,...
Your monitor is 11 years old. If the power light does not come on make sure the monitor is plugged into an electrical outlet and the power cord is securely connected to the monitor. If the power light still does not come on then you most like have a defective monitor.
If the power light does come on and you are not receiving a display from your computer then try connecting the monitor to another device. If you connect it to another device a receive a display then you know the monitor is good. At that point either the DVI-VGA connector is not compatible with your monitor or there is a problem with your computer.
May 27, 2014 | Computers & Internet
Dell 1704FPT won't come on at all. Only the sound
  • Check connection integrity at both ends of the video cable
  • Ensure the monitor and computer are plugged in to a working electrical outlet
  • Ensure power button depressed fully
  • Press the input select button the front of the monitor and ensure the correct input source is selected
  • Increase brightness & contrast controls
  • Perform monitor self-test feature check
  • Check for bent or broken pins
  • Re-boot your computer and monitor.
Jan 17, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Laptop battery charge indicator flashing amber and green
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the batter15.jpg light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
Apr 14, 2009 | Dell XPS M1710 2.33GHz Core 2 DUO T7600...
C593 Microtek
If it has speakers it wil have a female jack for you to connect the sound from your computer audio out(usually the green jack) to the monitor. It if does not have sound you can buty extenal speakers most places limke wal and k marts
Jan 13, 2009 | Microtek C593 15" Flat Panel LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Microtek 997M 19" Flat Panel LCD Monitor Logo
133 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
Michael Deni
Level 1 Expert
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
