Question about Ovens
I need help at trying to work this oven ... E.g what the symbols mean ... How to set the time ... Iv been trying for ages without any luck ... Hopefully someone can help me lol Thanks Tom
    Problem Solver:
  • 9 Answers
Tom,
I know it sounds moronically simple, but your best bets are:
A) Contact the dealer. He should have an owner's manual (free) available for you. If he's a really great dealer, he'll have someone come out to your house to set up the equipment for you. Either he or his installatiopn contractor should have done this for you. Little enough considering what you've spent.
B) If you're more confident, Google "Hotpoint + (Your Model Number)." That should bring up a link to the Product Manual, which you can print, or save as a PDF file.
If you do not understand any of the terms I've used here, you may email me at: joelb21@gmail.com
Good luck any way you choose to go! If you are NOT 100%m certain of what you are doing....STOP! You will be dealing with 220 Volts, and dont want to get hurt!
Joel Bergmann
Posted on Nov 04, 2012
5 Suggested Answers
  • 1462 Answers
SOURCE: meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Posted on Nov 05, 2008
milten1
  • 1304 Answers
SOURCE: door lock symbol flashes all the time
this may not be very helpful Gaggenau can be really tricky
ive seen this once before a long time ago but its worth a shot
the connection from the lock sensor might be loose
you should be able to unscrew the control and roll it up
right behind it you will see the lock and connections
jiggle em
like i said a long time but i believe the connection on the control board is green
Posted on Oct 08, 2009
ROMOAS
  • 97 Answers
SOURCE: use the pyrolitic oven clean setting, finished
some times unpluging the unit and waiting 5 mins and powering it back up will reset the unit and unlock it
Posted on Aug 30, 2010
  • 11 Answers
SOURCE: don't have instruction booklet - need to know
Hi, if you follow this link below, you can download your user guide, which will let you know what the settings are.
http://www.manualshark.org/m/aeg-b8871-4-a-instruction-manual-u25391-product-number-code-944185215-10006/
Posted on Sep 07, 2011
Oven , light and fan not working new element fitted 2months
Sometimes the timer display fades but still working in background, if all dead now then probably means you need new timer as ovens shouldn't work if clocks not set to manual mode.
Try turning oven on then messing with buttons, usually the 2 left buttons and one far right should do trick.. push 2 left first, keeping them pressed push far right!
warmest regards
Richard The Repairman
Mar 30, 2014 | Zanussi Ovens
I have a Zanussi oven without a manual. It has a rectangular screen with 9 buttons below it. It has numerous symbols for cooking and I have no idea what some of the symbols mean. Can anyone give me a...
I can tell you what the buttons are for but really you may need to get in touch with your local dealer or Electrolux to either get a hard copy or download one from their website.
Starting from the left is your main power button.
Then the oven function button.The next one is the fast heat up/defrost function.Next is the temp. control/current temp.Next the two with + and _ control time or temp.Next is the minute minder.Next is cooking time.
Finally the last one inicates end of cooking time.
May 03, 2010 | Zanussi ZBQ965 Electric Single Oven
Door lock symbol flashes all the time
jiggle em
Oct 07, 2009 | Ovens
Need to know how to use the timer
The manual for this Oven is available free to download at http://www.safemanuals.com Regards Vortash
Apr 28, 2009 | AEG B3101-4 Electric Single Oven
I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
Mar 27, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Broil feature not working
make sure element is getting voltage (120v)
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
