Question about Philips AJ3231 Radio Alarm Clock PHILIPS
My philips AJ3231 display starts flashing when the alarm comes on and I have to reset the time to stop it
  • Robert Stinson Dec 27, 2012
    Same thing happens to mine, did you find a solution?
    Same thing happens with mine, did you find a solution?
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
I have a AW60448W stopwatch that I can't get the alarms to turn off.
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: NowPrinting@BellSouth.Net if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Dec 28, 2010 | Watches
Set clock, date, alarm on SI686 CD/ Radio / Alarm Clock with Sound Soother
Can you clarify what you need help with? To SET THE CLOCK push the "Mode" button twice. (The current time setting flashes on the display) Once it is flashing, Decrease the hours by pressing "1" Increase hours by pressing "2" Decrease minutes by pressing "3" and increase minutes by pressing "4". If no additional buttons are pressed the time will reset in about 10 seconds and the display will stop blinking.
TO SET THE DATE press the "mode" button 4 times. The current date setting will flash on the display. Decrease the date by pressing 3. Increase the date by pressing 4.
Decrease months by pressing 1. Increase the months by pressing 2. The date will reset in about 10 seconds when you stop pushing the buttons.
TO SET THE ALARM Press the "mode "button once. The display will begin to flash. Change the hours by pressing either 1 (increase) or 2 (decrease). To change the minutes, press 3 or 4. 3 decreases the minutes and 4 increases the minutes. Once you have the time reset, leave the unit alone for about 10 seconds. the display will stop blinking indicating the time has been reset.
TO ACTIVATE THE ALARM push the round button on the far right. You will see the alarm icon come on or off on the LCD display on the right side. Be sure you have set the AM or PM time correctly on the alarm time. It helps to recheck this now as I have made this mistake several times.
If you get stuck on military time and want the 12 hour clock the answer is posted on this site, as well.
Hope this helps.
Dec 25, 2010 | Sharper Image SI686 Clock Radio
How do you set the time?
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Jan 13, 2010 | Watches
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
How to set date and time on a sports cardinal watch
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Aqualite stopwatch alarm
To set time:
To set Alarm time:
Feb 11, 2008 | Watches
Philips AJ3231 Radio Alarm Clock PHILIPS Logo
224 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
