Question about Microwave Ovens
Kitchenaide microwave kcms135hss-0 stopped working
This unit was installed in 1999 and has ben working perfect until now. There is power going to the control panel. the clock can be set, cooking times entered plus it counts down and beeps when time hits 0. The light inside turns on. However, the turntable does not spin, there is no motor sound and no heating being provided. Any help greatly appreciated. Would love to repair this unit vs. replacing with new inferior model. It seems that quality of almost everything on the market has diminished throughout the years. Thanks!!!
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Posted on Oct 12, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Posted on Oct 21, 2008
tiway1
  • 100 Answers
SOURCE: dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Posted on Dec 23, 2008
My Kitchenaide KEMC378KSS0 Oven Microwave Combo shut down.
Is it possible the cord got knocked loose during the work?
The parts list with exploded views is here.
My site is MicrowaveControl.com so feel free to e-Mail me at pupista@gmail.com for details and free advice.
Sep 27, 2016 | Microwave Ovens
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
My microwave oven just stopped cooking. The light comes on and the Motor is running, but much louder than normal.
The magnetron in your microwave has probably gone out. The magnetron is the part of the microwave oven that produces microwaves. If you unit is a built in model, it will likely cost more to fix than a new one. Same thing goes for a countertop unit.
Sep 10, 2012 | GE SpaceMaker Microwave Ovens
Kitchenaide microwave not heating - no stange noised, everying else seems to be working just no heat
there are few sensors inside that might go bad but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 27, 2009 | KitchenAid KCMS185J Microwave Oven
Microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Jan 13, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
