I have a tv/dvd combi and my son has pressed something on the remote and it now flashes DVD AUTO in the top right hand side of the screen and LAST MEMORY also comes up across the screen. It wont let me press anything on the remote or the tv to get it working can you help please.
    Problem Solver:
  • 7 Answers
Have you tried to unplug the system for 5 or more mins? It usaly clears the systems memory...
Posted on Jan 04, 2009
I have connected my jvc combi player to my tv via a scart cable. I then select the source button on my tv remote control and select scart. I can do and auto scan and it says completed, but no signal.
When using a scart cable, the TV should switch over to the Scart port that as last came active. Even when you switch on and choose the menu on the device, the TV should notice and switch over.
Just check if you are using a normal scary cable. Sometimes not really compatible cables with in / out switches, can spoil the fun, because not all wires are connected correct.
Jul 21, 2014 | Audio Technica Televison & Video
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
I have a dvd stuck in my Technika LCD 26-56D TV/DVD combi. Eject button on the remote control and side of TV will not eject the dvd. Screen is blue, indicating no DVD in the slot, but I can see it. Any...
Check the connection between the devices. There may be incompatibility issues. Or might the remote button not to make contact. Spread the remote, clean motherboard and contact sheet. Let them dry and reassembles.
Aug 11, 2013 | Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
Cant reset the region on my philips DVD736K player
Please rate my solution if this works:
1. Press the tray "open" button on the DVD player.
2. Enter the following numbers slowly on the remote control "1111" - 'note you will see nothing on the screen'
3. Press "0" on the remote (take note of TV screen to ensure you select the right number. TV should show " New region 0" in top left hand corner of screen.)
4. Press "open/close"
Feb 21, 2009 | Philips DVP5140 DVD Player
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Disneys pirates of the Carabean 13 iNch tv Remote cOntrol
I have a brand new remote for the TV/DVD combi (CRT not LCD TV) which is designed like a compass. TV had to go back as it did not work after Santa delivered, as Santa was out of Pirates TV's he replaced with another model but still have the remote.
Contact me at ricks90@hotmail.com if interested.
Rick
Oct 27, 2008 | Disney Pirates of the Caribbean TV/DVD...
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
No Picture on my TV
i had the same problem last night. On the top row of the remote, just next to the red power switch is a button that says v.select. I pressed it and the image returned to the screen.
Apr 12, 2007 | Koss KS4110 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
