Question about Compaq Presario CQ56-115DX Laptop
Fan won'tt work and computer wont turn on
Has had tea spilt on it, but worked after dried, got a new battery. has been charged, but when i try to turn it on the blue light(charged) goes to red(not charged). has been dropped, but sister in laws has also got dropped and still works just keys are messed . I don't even hear the fan turn on. Please help.
  • Compaq Master
  • 7,627 Answers
Laptop abuse, your luck it will work at all. It sound like it's done. You may have killed it
Posted on Nov 04, 2012
Kegtapper
  • 94 Answers
SOURCE: wont recognise battery
Those may have 1 or 2 different problems. Cold Solder joint on Mobo. Bad DC Power Jack. 1: if it is the Cold Solder, you can reflow the solder and be done with it. 2: if it is the DC power jack, It should be replaced. For simplicity lets call them DC(A) and DC(B) There are 3 connections to it. Gnd, DC (A), and DC (B). When the powersupply is plugged in, contacts (A) touch to send +DC to the laptop. (B) is open. When the laptop is using battery power, contacts (B) touch to send power from the battery through the system. Over a period of time (inserting and removing the DC Power Cord), the contacts become fatigued, or oxidized and the DC(B) never closes - so it won't work from DC Battery. RATE ME - if it helps
Posted on Dec 23, 2006
SOURCE: computer wont start
I ran into the same problem with my Armada E500. In my case, it was a faulty RAM module. What I would suggest is start by removing the battery, and the charger. Then continue by removing the plastic section above your keyboard (there is a single screw holding it in place on the rear end of the laptop. This plastic covers the right-hand hindge) from there, there are four plastic tabs that you slide down to remove the keyboard. This will give you clear access to the ram. Remove the module(s) and, using a soft eraser, gently clean the contacts. If your laptop has two sticks of ram, I would also recommend putting them in opposite ram slots. After that, replace the keyboard and plastic bezzel, reconnect the battery and charger, and try to boot it up again
Posted on Sep 15, 2007
  • 4 Answers
SOURCE: the bastard laptop won't turn on!
  •  It could be beneficial to unplug the laptop & remove the battery. Let the system sit & dry for a couple days. More than likely you will have to replace the keyboard. Could be more damage that you do not see. If it is a sugary drink like soda, it enjoys tearing up soldered connections. Best guess wouuld be let it dry out. If it doesnt work & replacing the keyboard doesnt fix it, take it in to a service center.
Posted on Oct 15, 2007
SOURCE: Lap Top Automatically Goes into Stand By Mode
needs either a new battery or power cord
Posted on Nov 06, 2007
SOURCE: My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Posted on May 30, 2008
Tea got spilt on it. It worked for a few min. then screen dark and won't light up. Everything else works. What do I need to replace?
Karen...
Even "clear" Water left with electricity will continue to cause damage... It must be dried before power is restored.
There is an immediate and urgent need to get ALL the power removed from any ELECTRICAL device that has moisture exposure.
If it was tea with milk... (mine was coffee with cream & sugar... full cup turned over on my DELL PC in 2002)...
I learned right there how to pull the battery... pulled the hard drive
rinsed it all the rest with clean water... and again with 90% rubbing alcohol... gently blew everything dry with compressed air and let it all dry for several days... turning parts over each day.
Three days later I reassembled it all back together
and it is STILL running TODAY.
Hope this helps!!
May 15, 2016 | Cell Phones
My samsung s5230 got tea spilt on it. won.t turn on.
Take the battery off. Leave the cover off. Put the phone in a bag of rice. Make sure it's completely surrounded by rice. Leave for at least a day. Two would be better. Clean the phone off, reinsert the battery, plug it in to power, and try it. If it still won't power on, getting it wet with the battery in has shorted out components and blown them. If it does work, all's well.
Jul 06, 2011 | Cell Phones
I spilt tea on the keyboard of my dell netbook, i took the battery out and took the power cable out and dried it all now when i turn it on the screen is fine but it beeps very loudly
The beep is a warning code indicating that there's an error in the start-up process. You'll have to have your laptop serviced from a qualified technician because there may be some damage to the motherboard.
May 17, 2011 | Computers & Internet
I have spilt tea in my set box hand control can
i could be ok take the batteries out,then wash out properly with warm water and let it dry out fully near a radiator for a couple of days and try it then. It has worked for me everytime if you have the knowhow and the tools to take it apart then do so it will speed up the whole process
Oct 31, 2009 | Thomson Audio Players & Recorders
I spilt a cup of tea on my laptop and i left it for a couple of weeks and now it will charge but wont turn on but i have had the motherboard out and cleaned it with cotton buds
You should removed the battery, dismantle the laptop now was the parts with distill water using brush and again wash it then keep it in standing position under running fan for a day. Make sure taht all parts are dry now assemble and put it on it should work.vikram00rathore@yahoo.co.in
Jul 11, 2009 | Computers & Internet
Acer Aspire 5100-3583
Hello Citiboy,
Well it sounds like the power circut is gone. That regulates things like charging and power distribution etc, which would explain your problems. If that is the case then its a new motherboard as it cannot be fixed.
However before you do that try this..........
You would be very amazed at how a single drop of liquid can hang about a board (on a chips leg for example) for weeks and it MAY be that even if there is no liquid on the board that the residue from the tea could be causing the problem...so ..... go get some isopropranol and also some non-deionized water.
Simply remove the motherboard and wash it with the water. The fill a small bowl with the Isopropranol and place the board in it and swill the liquid about it for 10 mins.
Leave it over an hour and then take out of the isopropranol and dab it dry with an absorbaint cloth (DONT RUB). then place the board in a warm area for 2 days to air dry.
I think you will find that when you rebuild the computer and switch on, that its all working fine.....Fingers crossed.
Good Luck.
Oct 22, 2008 | Acer Aspire 5100 Notebook
Tea spilt ok Thinkpad Keyboard
I'm sorry, but there are no alternatives, and you may have bigger issues than just the keyboard. If the tea seeped past the keyboard, and onto the motherboard, which is directly bellow the keyboard, then by trying to start it you may have fried the motherboard. You would be surprised how long it takes for a laptop to dry out, 6 hours is not near long enough. You will also want to clean it, the sugar in the tea can cause corrosion of the circuitry on the motherboard. I'm going to recommend that you take it in for a professional diagnostic and cleaning. This way you will know the exact extent of the damage.
Sep 03, 2008 | IBM ThinkPad T30 2366 Notebook
Computer wont turn on
How long ago did this happen?
Remove the power adapter and the battery.
Remove any removable covers from the bottom of the laptop and look for any signs of liquid. Leave the covers off for a couple of days to allow any liquid or moisture to dry up.
Press and hold in the power button for up to 60 seconds to discharge the laptop.
When you are sure there is no more moisture present try starting the laptop.
If it still won't turn on something may have shorted out during the spill and you will probably have to take it to a repair shop.
May 05, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Motorla l6
 i wont suggest u this at home ...  a practical solution for this is " u need to dismantal  ur phone  and dry it in the sun 4r 2 .. 3 hrs ...............if this also wont work need to concern moto care center
Oct 19, 2007 | Motorola Mobility L6 Cellular Phone
Compaq Presario CQ56-115DX Laptop Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
