Question about Baby Gear
Techno gym treadmill E5
Treadmill stops working and shows E5 on screen
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
  • 218 Answers
SOURCE: I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
  • 3 Answers
SOURCE: My Bowman treadmill 7 series
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
Posted on May 05, 2011
  • 33 Answers
SOURCE: My TX 5.0 RC Sportcraft
You will have to unscrew that part out of the treadmill and take it out, and then put it back in to see if that makes any difference. If for some reason that does not work, you may have to contact the company to get a replacement on your treadmill, or to see if they wil fix it for you. Since each treadill is different, defects are inevitable, so a person will have to use consider going this route if all else fails.
Posted on Jul 13, 2011
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
My techno gym treadmill 700 indicates equipment is blocked code (4) how do I fix this problem. Thanks
Can be one of many problems.
Can be as simple as a limit switch not resetting.
Can be a cable is bad
More often than not it's the lower kit (electronics near the motor) that is blown though.
Mar 09, 2015 | True Technogym Excite Run 700 Treadmill
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 24, 2013 | True 850 ZTX-P Treadmill - Serviced
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
Trimline manual
follow this steps and fix i.t God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • Sponsored Links
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2gXuRx33v
    Oct 02, 2013 | Exercise & Fitness
    The equipment is blocked
    hi all i have run excite ur 500 treadmill from techno gym company i face block on screen i think it's board problems if anyone can have any idea contact me at email: alex.freemas@gmail.com
    May 08, 2012 | Exercise & Fitness
    E5 error code on sportcraft tx400 treadmill
    E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
    and error code appear.Can you tell me what this means? How to solve this problems?
    Nov 24, 2011 | Exercise & Fitness
    Tredmill not moving
    That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
    Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
    Baby Gear Logo
    16 people viewed this question
    Top Baby Gear Experts
    Dorel UK
    Dorel UK
    Are you a Baby Gear Expert? Answer questions, earn points and help others
