Question about Sceptre Televison & Video
Spectre 32inch led ty picture center faded
Picture comes on when power button turned on but middle ofr picture is allmost black
  • 127 Answers
Check the panel Screen If voltage Is there?
Posted on Nov 04, 2012
  • 367 Answers
SOURCE: TruTech PLV1615T has Sound but No Picture
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Aug 23, 2008
Shuttle83
  • 1139 Answers
SOURCE: black screen
This denotes a power supply issue. I would venture to say that it is the part of the supply that controls the plasma ignitor if this is a plasma TV or if this is an LCD screen it is called the back-light and inverter circuit. The power supply board would be the chief culprit in this case.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 21, 2008
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40V300 won't turn on.
Unfortunately 5 blinks is a LCD panel error. The only way to fix it is to replace the whole LCD panel. This is the most expensive part in the TV.
part number: 1-802-488-12
List price: $1336.32
Core charge: 1790.00
You could try to replace it yourself but would need to take the whole TV apart by first taking off the back cover, then removing all the boards in order to get to the panel before putting it back together but I would just recommend buying a new TV as the price of the repair exceeds the price of a new TV of the same size.
Posted on Oct 13, 2009
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Feb 09, 2018 | Vizio Televison & Video
Powers on, backlight comes on then power LED and backlight slowly fade and turns off after about 45 seconds.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 02, 2015 | Vizio E701i-A3
Screen trys to show desktop, but quickly fades to
Since the power led button is on, the problem with your monitor is the that the picture board of your monitor has develop fault, that is why it tries to show your desktop and quickly fades away.
The picture board of your monitor is bad and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | ViewSonic VX924 19" LCD Monitor
When i print a page in black allmost all the page comes out faded. The last right part of the page comes out ok. I have changed the black cartridge but the problem persists. any ideas?
This is the problem of black developer in the imaging unit. you have to change the black developer. Kindly approach authorised service center in the region
Oct 05, 2009 | Samsung CLP-300N Laser Printer
Hp media center pc won't turn on after electriticy went off & came back up & use surge protecter. LED on back of pc comes on & then off very quickly when power cable is plugged. any ideas?
Unplug the power cord and hold the power button in until the light on the front comes on and fades out,The plug the power cord back in and start as normal.
Mar 13, 2009 | HP Pavilion a705w PC Desktop
Samsung clx-3160fn
This is usually due to the imaging unit going out, but can also be a problem with the main board itself...unfortunately that means rma is really the only option...which is NOT going to be fun fyi as samsung has poor customer service.
Aug 30, 2008 | Samsung CLX 3160fn All-In-One Printer
Panasonic PT-61LCX65 61" Television Set Popped, Now Left with a Cicking Sound
Your problem more than likely lies in your lamp. The whirring noise you hear is the ballast trying to fire up the bad lamp. The lamp part # for your set is TY-LA1000 and can be purchased online at vance baldwin. This is something you can easily replace yourself and your owners manual will give you instructions. Hope this helps
Mar 31, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Erropr code #1200 Lexmark X4270
Tried what blkghost suggested above but had to tweak his advice slightly.
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Nov 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
Televison & Video Logo
118 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
