Question about Samsung VP-W70U Camcorder
Can i connect my vp-w70u to the laptop, having trouble trying to do it
  • Susan Giffith Nov 06, 2012
    Hi, i have video grabber leads to connect samsung vp-w70u to my laptop. When i have the leads all connected, nothing happens and wont send my video to the laptop. Have been told i need a device called video capture, could anyone advise me how to get this please?
Can i connect my vp-361 direct to a usb port ?there is a cable where it need a special connection to the pc
Hi Willy, i have the same problem. Im trying to connect my Samsung VP-D361 Mini DV Digital Camcorder to my laptop (Windows 7) but I cant. Is the problem with the O.S driver compatibility?
Mar 16, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
Eject...L for no reason
EJECT....L means that your camcorder has a mechanical failure.
after power reset (taking out the battery and putting it back in) and the camcorder is still doing the same thing you should send your camcorder in for repair
Jun 24, 2009 | Samsung VP-W70U Camcorder
I have a samsung mini dv digital-cam VP-D351 PAL and im trying to connected it to the computer but its not being recognised by the laptop. Thank you for any information that you can give me.....
If you are running windows vista this will be the problem.There are no drivers for vista firewire..If other windows then try samsung support for required driver.
Sep 07, 2008 | Samsung Compact MiniDV Digital Camcorder
USB device not recognized on my VP-D371i Samsung digital camera
i am also have Samsung VP-D371i if u need help my icq number is 400 952 967, but my Samsung VP-D371i do not support usb iam use other line
Feb 23, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung VP 500 L Help !
BAD CCD. SAMSUNG IS KNOWN FOR THIS. YOUR OLD TAPES WITH GOOD RECORDINGS PLAYBACK GOOD? YOU CAN RECORD AUDIO BUT NO VIDEO ? IT IS A BAD CCD
Oct 17, 2007 | Samsung VP-W70U Camcorder
Everything black and white through viewfinder
It is supposed to be. That's just how these cameras work.
May 27, 2007 | Samsung VP-W70U Camcorder
Video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
May 21, 2007 | Samsung VP-W70U Camcorder
Focus trouble
If your unit has a switch for manual focus, put it in manual. If you cannot focus the unit in manual you have a problem with the lense and it will need repaired and/or replaced. If you do not have manual focus you will not be able to troubleshoot the unit. It could be a lense problem as stated before or a problem with the Auto Focus system, perhaps just out of adjustment, or something more serious. Either way if you are not capable of camcorder repair you will have to seek the help of a reputable repair shop. Good luck.
Jun 12, 2006 | Samsung VP-W70U Camcorder
Samsung VP-W70U Camcorder Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
