Hi Brian, I have a Dane-elec 8 Gb jump drive that is asking me to format, but if I do I will lose all data on it.
When I put it into my computer it is telling me to format it, but I will lose all data on it. I REALLY need that data, what do I do? Is there a way to save the information before formating?
  • T Smith Nov 05, 2012
    Hey Brian I got all the way to check now and it is still asking me to format. Said it could not be done because it is not formatted. What should I do now?
  • 27,725 Answers
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Posted on Nov 05, 2012
  • 55 Answers
SOURCE: It keeps asking me to format to use the drive
Some times ago I faced problem like this. I discussed with an expert from local market about it On his suggestion I arranged an other hard disk and connected my PC. Note that I was already using two hard disk one as a master, 2nd for slave and the third one of same size of defective hard disk. I installed hard disk migration software on the master. I successfully copied all data on the secondary master. There is no need to make same partitions. The software will automatically make same copy of the disk to the destination disk including equal partions if they exists. Remember you have connect three hard disk with the same PC. I can arrange address of the software for you. Feel free to mail me at:
ABDUL MANNAN SHAD
LAHORE, PAKISTAN
abdul_mannan698@yahoo.com
MOB:03456346984
Posted on Dec 14, 2008
SOURCE: Dane-Elec USB not working!
How I got it to work in XP Pro:
1) Plugged USB Drive in and saw it saw hardware manager install it but didn't see new Drive Volume in My Computer
2) Opened Control Panel
3) Open System
4) Clicked Device Manager from Hardware Tab
5) Expanded Disk Drives
6) Right clicked USB Flash Memory USB Device and hit Properties
7) Clicked Volume Tab and hit the Populate Button. Voila!
HTH
Posted on Jan 08, 2009
map9966
  • 2351 Answers
SOURCE: how to open without format when i open my drive it displayed do u want to format if i foramt my drive i will lose my data pls tell me how to open it without format
Windows has found a problem with the F.A.T. (File allocation table), thus windows wants to format the drive. Other Dos mode commands like FIXMBR, (fix master boot record) may make retrieving your data impossible.
There is a way to get around this with out loosing all your data.
Before we get started I need you to check the data cable & power cable connected to the drive. Unplug the power cord from the PC. Open your case. Disconnect the power cable & data cable from the drive. Than re-connect the power cable & data cable, follow the data cable to the motherboard & check it's connection.
(By doing this you are making sure the cables are fully connected, sometimes they come loose but you can't tell just by looking at them). Put your case back together & plug in the power cord.
Load your windows CD into CD-ROM. Start up your system & at the same time press the F8 key on your keyboard every two seconds. A screen like the one below will load;
Choose your CD-ROM with windows in it.
Windows will see you have a version installed & it will give you other options. Read the screen prompts. You want to create a partition within the free space of your drive. Follow windows instructions. Windows will creating a new partition . Install windows into that new partition. (This will be a full install). Your old windows will not load.
The data within your old partition will not be deleted!
When you have finished installing windows update it. Install motherboard drivers, printer drivers & programs ect. When finished you can now copy folder & data to the new windows. (All this will take time). Most data will be located in folder shown below. You can copy & past the data / folders from the old partition to the new windows;
C:Documents and Settings User nameApplication DataMicrosoftAddress Book
C:Documents and Settings User nameDesktop
C:Documents and Settings User nameFavorites
C:Documents and Settings User nameLocal SettingsIdentities
C:Documents and Settings User nameMy Documents
Data from any program you may have installed.
When you are 100% sure you have recovered all your data, you can delete the old partition through windows disk management. How to run disk management?
Click the start button & click Run. Type, diskmgmt.msc into the run window & click ok. Within in disk management you'll see all partitions on your hard drive, you'll also see your CD-ROM & any other drives What was once your C: drive will most likely be labeled to another letter. To find your old windows right click on a drive within disk management & click open. (Make sure you do not delete the wrong partition / Windows).
To delete the old partition right click on the old partition & click, Delete Partition. Close all opened windows & restart. Windows will automatically add the drive space to your new partition.
Operation complete.
Mike
Posted on May 06, 2009
SOURCE: External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Posted on Jun 23, 2009
  • 1584 Answers
SOURCE: My Dane-elec 4GB usb flash drive , no drivers?
Try it in another PC, if the same its a writeoff.
Posted on Mar 09, 2010
Dane elec 8gb
Insert the first car into the device, copy the data to the computer through a cable and repete the process but, then copy the data from the computer to the new card.
Nov 28, 2013 | Skque 8GB MicroSDHC / MicroSD / Micro SD...
Dane elec 80 gig will not format although when installed into usb slot, it says that it needs to be formatted. (windows 7)
You will have to be the computer administrator to change any values on any of your hard drives
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 this will also apply to usb drives
right click on your usb drive select properties select sharing then select advanced sharing make sure there is a tick in the share this folder box
click start click on my computer you should see your dane elec 80 GB usb copper drive right click then select format
another way is to control panel administrative tools computer management disk management right click on your 80 GB copper drive select format
hope this helps you
Oct 06, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My Dane-Elec 8GB will not format. I have tried two different jump drives and I keep getting the same message. Unable to complete format.
WHAT A PAIN IN THE A_S_S.
DID EVERYTHING DESCRIBED, & MORE,
& I'LL NEVER WASTE ANOTHER PENNY ON
ONE OF THESE F_U_C_K_I_N_G PIECE OF
S_H_I_T DANE-ELEC 8GB .
I'M GOING BACK TO TARGET STORE & JAMMING
THIS NIGHTMARE RIGHT UP THE STORE MANAGER'S
STUPID A_S_S .
Sep 12, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Put in my dane elec 16 gb flash key on my computer window ex and other computer window 2007 not recognized its malfunctioned. light is out... need to get all my important files out..
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htmwww.CardRecovery.com
Apr 20, 2011 | Dane-Elec DaneElec 4GB USB Drive Blue Hard...
Computer wont reed usb drive dane elec 4 gb usb drive
use a program called recuva (http://www.piriform.com/recuva) to see if you can pull any lost info form it. id recommend reformatting with hp usb format tool. if both those programs don't detect a usb drive its broken but you may get a new one form dane-elec if you contact their customer support. personal experience in replacing 4+ usb drives form lexar through customer care
Mar 08, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
I have a Dane-Elec 4 GB Flash drive. I used it successfully one time, but the next time I put it in my computer (or any computer after that) the computer recognized the new device but told me "Please...
1) Instead of double-clicking, right-click and choose "explore." I hope it's that simple. Once you're in, look for a file called autorun.inf. Delete it.
2) If it won't let you explore, see if there is a "format" option instead. This will possibly solve your issue of access, and will solve your issue with your confidential data (of course, your data will be gone, but I'm guessing you're OK with that).
3) Try using another USB slot, sometimes there could be an issue with specific slots, especially if you are using hte front USB ports on a desktop
4) I know this may seem silly but turn off the computer, and then unplug the computer from the wall. Leave it unplugged for 30 seconds, plug it in and then boot up the systems. Plug in the USB drive.
5) Finally if the unit still is not being seen, it may need a low level format, contact the manufacturer and see about getting a replacement. I found their e-mail at onlinesupport@dane-memory.com
Feb 27, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
Mar 25, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Sandisk 16gb microsd formatting incorrectly
Hi unfortuanley you have been sold a fake card
http://memory-cards-blog.blogspot.com/2009/12/dane-elec-8-gb-compactflash-memory-card.html
Please can i ask that you leave ffedback and vote if this has been useful
Feb 09, 2010 | SanDisk 4GB microSD High Capacity Memory...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
