Question about Toshiba TLP-S10 Multimedia Projector
No video picture
I have a Toshiba Video Projector. (TLP-S10). I have a normal signal on the progjector from the laptiop computer because I can see the projected image of the desktop and any windows, applications, and photos I wish to open. Everything appears to run normally as before but now as soon as I run a video. I can only see it on the Laptop's monitor but not projected on the screen. I have tried Windows Media player and another video application and I can only see the taks bar across the bottom but not the video image itself. Can you help?
  • lework Jan 06, 2009
    Would you or anyone you know be able to be more specific about what exact setting changes either on the laptop, media player, or video projector I could try? Thanks for any assistance you could give.
  • 192 Answers
It might be the projecter settings or the setings for you viedio player. One other thing is that itt could be the computer setting you have.
Posted on Jan 04, 2009
  • Michael Ward Jan 04, 2009
    your video play might not alow you computer do do this or it is the setings you have on the projecter it self.
What lead should purchase
To buy a HDMI-VGA adaptor (a adaptor adjust HDMI to VGA)
Feb 15, 2014 | Toshiba TLP-ET1 Multimedia Projector
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
What is wrong with my tlp s10 it gives the entire picture a blue tint the lamp has done 2700 do I need a new bulb
Check the Video cable that feeds the projector, could be a broken cable or a pin bent -worst case the connector on the projector has broken.
Try the VGA cable on your computer screen.
The lamp does not need replaceing, the lamp emmits white light only.
Aug 06, 2010 | Toshiba TLP-S10 Multimedia Projector
Connecting projector to Dell Vostro 1500 but getting no signal message
Press <Fn><F8> to switch the video image between the display only, the
external device only, or the display and the external device simultaneously
Feb 17, 2010 | Toshiba TLP S30 Multimedia Projector
I have a toshiba tlp 770 projector. The image is not sharp and i bought it on ebay. How do I make the image sharper?
first, reset the settings to factory default. if you are using it with a computer, make sure it matches resolution. native for the projector is 1024x768, but maxes at 1600x1200. and the input is analog, not digital. if you are doing video, make sure you are on the correct video input. it does do hdtv, but not 480p or 480i. if none of this helps and the focus does not work, check case for signs of damage. maybe the previous owner dropped it and damaged something internal. last possibility: clean it out using compressed air. take the top off if necessary. since it is an lcd projector, dust and dirt build up on lenses and light filters causing them to burn. remove the lamp and look at the fly-eye lens inside the lamp housing. if you can see the one behind it, check for burn marks. there may be parts that need replacing.
Aug 15, 2009 | Toshiba TLP-770, TLP771 Replacement...
No signal projector (TLP-S71)message connect to laptop
make sure the cable is good. then make sure the resolution matches.
Jul 28, 2009 | Toshiba TLP S30 Multimedia Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
Video Projector from Toshiba
I think it might be the video player or it might be the computer settings and the projecter settings.
Jan 06, 2009 | Toshiba TLP-S10 Multimedia Projector
Unsupported Signal
Hi Circuitrider
Just change the resolution on your PC to match that of the Projector i.e. XGA Projector = 1024x768 resoltuion.
If the problem still persists , the Mainboard is at fault and will need either replacement or repair.
May 13, 2008 | Toshiba TLP S30 Multimedia Projector
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
Toshiba TLP-S10 Multimedia Projector Logo
181 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
