Question about Lands Phones
Panasonic kx-TGA246W flashing screen with or without new batteries
  • jerry631
    jerry631 Nov 06, 2012
    Phone blinks with screen going on and off but it still functions. You can see the phonebook as it flashes. Very hard to use. Replaced battery but no inprovement. Can use it to answer calls. Thanks for your help.
My phone is panasonic kx-t7730 white advanced system HYBRID SYSTEM it does not ring in the day time mode
it may be the battery for its memory be dead...if this is true the phone installer can straighten it out for you
Jan 18, 2014 | Panasonic Advanced Hybrid Kx-t7730 White...
Flashes yellow light
I have found that this problem will also happen when the batteries are failing. You can verify this if you have multiple handsets as only the bad one will have the blinking yellow light. At one point the display will not show either.
Jul 22, 2013 | Panasonic Lands Phones
Panasonic KX-TG6700 Phone
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Oct 03, 2012 | Panasonic KX-TG6700 Phone
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
My hand set is not working even after charging
you need to flash your mobile. And it will be online again :)
Feb 27, 2009 | Panasonic Phones KX-TG5571
KX-TG1032
If you have Caller ID, the calls you have answered (or looked at on the screen) have a check mark by them. To erase missed calls, page through the Caller ID screens until you have viewed all the calls without a check mark. http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/FAQs/model.KX-TG1033S.F#ts Hope this helps.
May 10, 2008 | Panasonic KX-TG1033S Cordless Phone
How to disable dial lock without password
I am using panasonic PANASONIC KX-TG2620BX and was locked by my daughter. We had it unlocked by:
press MENU
select Dial lock
Enter password 1234
Press save
Turn off Dial lock? press yes
Jan 08, 2008 | Panasonic 5.8GHz Cordless Telephone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
