RCA HD TV Model#: F38310. Input stuck on "0". Will not change to Video 1, 2, 3, Front, or CMPT. Tried black button on top of TV, remote, reboots, power plug off. Thank you. Cheech
    Problem Solver:
  • 21 Answers
Have a scart connexion ?
Posted on Nov 04, 2012
  • 476 Answers
SOURCE: cannot change input source for tv
i would try the abvious first, unplugg the tv from the ac outlet and wait for a few seconds then try turning tv on see if the problem is solved, if not it might be that the key board panel needs replacing.
Posted on Aug 02, 2009
maatmartin7
  • 1212 Answers
SOURCE: hi! I have a problem with my sony bravia lcd tv
You may have a case of a bad signal board. The clue was that your power button on the tv and remote are the only ones functioning. If the tv is still under warraty, call the service number to get help!
Posted on Nov 16, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
  • 210 Answers
SOURCE: lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Posted on Dec 12, 2009
Testimonial: "Your response was quick pointed me in the right direction I might need help with ID of components to continue"
SOURCE: TV is on but says it is still powering on
try unplugging the ethernet cable
Posted on Feb 17, 2010
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
Sep 25, 2015 | Symphonic Televison & Video
HOW DO I GET cmpt off the tv screen?
i need more information about cmpt
Feb 18, 2015 | RCA TruFlat 27F520T 27" TV
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
Concierge by Zenith Input Problems.
I had the same tv at my motel and wanted to hook up my Wii. Turning to Channel 999 worked.
Jan 17, 2008 | Zenith C27A24T 27" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Tv antenna
Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Jul 21, 2007 | RCA F38310 38" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
