Question about eMachines T5062 PC Desktop
Emachines Will not detect ethernet cable
My desktop is not picking up the ethernet cable even though it is connected , I really need help on this guys please help me.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
With the machine on and the cable connected on both ends (1 to computer and the other end to the Router or Modem that needs to be powered up) look where the cable plugs into your computer. Is there a green or orange light on. There may be two. Normally one that stays on steady is the CONNECT. This one is normally green color LED. When Data is being transmitted a second LED will be flickering showing data transfer. If you have no LED lights showing directly by the Ethernet cable, try another cable. Reminder: also make sure you have power on the router/ cable/dsl modem.
Hope this helps..
Posted on Nov 04, 2012
I NEED TO CONNECT AN ETHERNET CABLE FOR WIRELESS CONNECTION.CANNOT FIND A SUITABLE PORT!
Your computer should come equiped with an ethernet port. If it does not then you can get a male/female ended ethernet cable connector which can plug one end into USB and the other into an ethernet port.
Nov 13, 2009 | E-Machines eMachines Desktop PC
Last week I put a 4-hub on my desktop and laptop. one wire from wall to main hub, one ethernet cable from hub to laptop, one ethernet cable from hub to rear ethernet port on desktop. The internet on the...
check if we are getting good ip address 192.xxxxxxxxxxxxxxxxxx
not the 169.xxxxxxxxxxxxxx
relese renew if 169.xxxxxxxx is the case
if no reply.. try using another cable and check the connections
Sep 20, 2009 | Dell Latitude D600 Notebook
Needed driver for Network : 10/100Mbps integrated Ethernet driver
Gateway (eMachines manufacturer) has a driver database for your model of computer. I myself have several eMachines of my own and am pretty sure they all have the same 10/100 Ethernet board. If you are unsuccessful with Gateway, write back and I will send you what I have.
Sep 20, 2009 | E-Machines T6420 PC Desktop
I have a Dell Dimension 3000 desktop, around 5-6 years old. It is connected to the internet through a cable modem then through a wireless router, but it is connected with a LAN line. If I try to connect to...
Sounds like the actual ethernet adaptor (hardware) may be out but first I would run a really good spyware and see if it is infected. This one works really great (see link at bottom) although, it is not free but you can download, installl and it will run scan and tell you if you have malware (which is why it will not connect). It only cost 30 bucks to purchase which is reasonable to take off the malware and get back online. Beats a techs fee.
If there is no sign of malware, then the hardware is out and you will need to replace. These can be purchased at Wal-mart for under 60 bucks. Hope this helps!
http://www.enigmasoftware.com/
Sep 13, 2009 | Dell Dimension 3000 PC Desktop
Media disconnected
If you are using one box (or modem/router) only, when your computer says media disconnected, it means that your computer does not detect your modem.
You can try unplugging and replugging the ethernet at the back of your computer or laptop. make sure that the light on the ethernet port is lit up (especially for desktops, not sure about laptops though).
You can also do the same process with the ethernet cable from your modem/router. if your modem/router has other ethernet ports in it, try to connect it to other ports as well. If your computer still says media disconnected, try purchasing or borrowing a new ethernet cable.
Also make sure that your ethernet adapter is working properly and that media disconnected follows after ethernet adapter local area connection and not wireless connection.
Hope this helps!
May 04, 2009 | D-Link AirPlus DI-524 Wireless Router
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
Ethernal Controller Problem
click start
click connect to
show all connections
look to see if lan or high speed internet shows connection.
If enabled and not working look on back of computer to see green light from ethernet plug.
if no green light try different ethernet cable, if that doesn't help replace ethernet card less than $20
Mark
if you need more let me know
Apr 11, 2009 | Gateway GT5220 PC Desktop
Wireless connection issues (to be origional lol)
Is your desktop pc still working fine.., clear your preferred wireless networks in your laptop, try searching for the wireless network again, check if you are abe to pick up any other wireless network in your laptop, so that you can conclude whether the problem is with the laptop or the router..if not try reconfiguring your wireless settings in your wireless router and check it out ,that will fix your problem..all the best..
Aug 17, 2008 | Computers & Internet
eMachines T5062 PC Desktop Logo
104 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
