Question about GE DBSR453EBWW Electric Dryer
What type of power cord ( 3 or 4 prong) for an electric dryer
I have just gotten a Kenmore 30 amp dryer electric dryer and want to know what type of cord I should use, Sears was no help
  • 706 Answers
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Posted on Jan 06, 2009
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
Got a used dryer had a 4 prong my house is 3 prong, changed the 4 prong to 3 prong plugged in and wont turn on, what do i do?
There is a difference between how a 3 prong and a 4 prong power cord is installed. Please read the following link:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have the power cord installed correctly and still do not have power, please check for 220-240 VAC at the wall receptacle. If you require additional assistance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 05, 2010 | Kenmore 64902 Electric Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
I have a dryer that has a 3 prong cord however the connection at the wall is a 4 prong outlet. I need to know how to change it.
The following link explains how to convert a 3-prong power cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and the Ground (Green or Bare Copper) wires are terminated at the terminal block. In a 4 -wire configuration these wires are independent of each other. In other words, neutral does NOT get grounded.
If you have any questions, please let me know. I hope this helps you.
Oct 06, 2009 | Kenmore 62602 Electric Dryer
Swapping dryers
just remember a 3 prong cord the middle wire goes to the middle on the terminal block,the other 2 does not matter there both 120 volt,same if you have a 4 prong,the white wire goes on the middle on the terminal block,the red and black go on each side and the extra green gets mounted to the cabinet,,let me know how you do-mike
Mar 23, 2009 | Kenmore Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
111 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
