Question about Fuji Zoom Date 60 35mm Point and Shoot Camera
Camera not working-please help
While loading film into the camera, it made the sound it always makes when I close the door, but instead of showing how many exposures I had used, it flashed "E2" and this has been flashing ever since (which was yesterday). I've changed the batteries and reloaded the film multiple times to no effect. Any suggestions?
  • reevasi Dec 17, 2008
    I have a fujifilm camera that is flashing E2 as well. I've tried changing the batteries and putting in a new roll of film - no change? any solutions?
  • haley586 Dec 17, 2008
    I have the same problem. Loaded the film, closed the door, heard the noise as if the film were loading, E2 error message flashing since--not able to take any pictures.
    Habit-Forming:
    New Friend:
  • 14 Answers
No promises but if you take a roll of film that is already light fogged etc. and load it into the camera. Let it wind as normal. Now we need to work quickly: Press the rewind button. While it is winding OPEN THE BACK. It won't rewind very long because very little film is out of the cartridge so be ready. This will fogged a bit of the film but it does seem to clear the error. You can still shoot the roll if you just skip the first few shots.
Posted on Jan 09, 2018
4 Suggested Answers
  • 33 Answers
SOURCE: E2 Error Messagg
Dear Haley
Perform the following steps:
  1. Power off the camera.
  2. If you have a memory card in the camera, remove it.
  3. Remove the camera's batteries, then wipe the battery contacts with a soft, clean cloth.
  4. Reset the camera.For this refer to your camera's User's Manual.
  5. Reinstall the batteries.
  6. Power on the camera.
This should work.please rate this solution.Thank you.
Posted on Dec 17, 2008
  • 185 Answers
SOURCE: Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Posted on Dec 11, 2009
  • 102366 Answers
SOURCE: Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Posted on Apr 11, 2010
I have a Pentax ME super and the film door will close when there is no film but when i load it with film its not closing properly?
I really loved your camera type though it was 35 years ago I had one. I envy you.
Not sure why you should be having trouble unless you have a bad film. Have you tried more than one film?
If the film cassette has dropped in properly and is laying flat, the film rewind has to be raised, I think, to allow that and the sprocket holes in the film are properly engaged with the sprockets and the free end of the film engaged onto the film wind-on reel then everything should be well below the door aperture.
I would wind on maybe a frame and fire the shutter prior to closing the film door just to observe everything moving as it should and then close the door.
The last quarter inch the door must be closed against the pressure of a spring but if the little spring-loaded device behind the door which is intended to keep the film perfectly flat against the camera body is working correctly only a light pressure will be needed to compress those springs and close the door.
Perhaps something is wrong there?
I don't remember any problems closing the film door.
I hope this helps but if it doesn't please come back again and describe your actions and the feel of the door more fully.
Feb 04, 2015 | Pentax ME Super 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
I have no idea how to put my film in the "Pentax mz-m" camera? Someone help me. I'm new to this as I am just doing photography at school!
Pull up on the rewind knob ( left side ) to open the film door. put film cassette in chamber then lower rewind knob and pull enough film leader to the take up spool. attach film to spool. close the film door then advance the film to #1 on the counter.
Jun 06, 2009 | Pentax MZ-M 35mm SLR Camera
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
How to put film in the camera
Hey buddy5000,
The process to load film into your camera is as follows
1. Turn the camera on and make sure the frame counter reads 0 if it doesn't there is probably film in the camera.
2. Press the film door release button and slide the release downward.
3. Place the new film cartridge in the film cartridge chamber and pull out the film leader until it reaches the red dot on the bottom right side of the film chamber. Make sure the holes on the lower edge of the film engage the teeth on the sprocket.
4. Now close the back door and the film should load automatically and# 1 should appear in the frame counter, and if it does not then the film is not loaded properly.
I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 10, 2008 | Minolta Maxxum 5000 35mm SLR Camera
Nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Oct 03, 2007 | Nikon N75 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Fuji Zoom Date 60 35mm Point and Shoot Camera Logo
83 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
