Question about Haier Televison & Video
Will not set tv channel to 3...keeps telling me to please run channel auto scan
Have run channel auto scan 10o0 time nd won't set. I only Havel cable remote not tv remote
  • Anonymous Mar 15, 2014
    how to auto scan your TV Remote
  • 127 Answers
You can do it manaly.
Posted on Nov 04, 2012
Done ran auto can't get rid of it on TV
Posted on Jun 07, 2013
4 Suggested Answers
rickbrashear
  • 176 Answers
SOURCE: can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Posted on Aug 06, 2012
AJIN G
  • 6694 Answers
SOURCE: I have TCL TV set.
Hello
The mamory IC inside the circuit of your tCL tv is faulty. Memory IC is one which transfers data to main system IC when we switch the set ON each time. Now it transfers the data to the system IC ofcourse, but not memorize the [LPM]; last position memory. This IC can be located very nearto the main system IC; will have 8 solder terminals. It can be easly unsodered out and resodered in. Its number is most important. Keep a keen look on its number and buy an exact replacemnt. It will be very cheap to buy, and can be had from most of the electronic spare part shops at your town. OK.
Posted on Jun 29, 2011
  • 12 Answers
SOURCE: Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Posted on Oct 07, 2012
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Oct 26, 2014 | Calypso 26"" LCD Hd TV
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Keeps telling me to run an auto channel scan
Check and replace its main system control memory IC. It is faulty. It does not hold the data. Gopakumar Gopalan Google
Feb 26, 2014 | Orion 24RTC 24 in. TV
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
Sep 13, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
AOC LCD27H060 won't find channels
Check your antenna cable connection. Check the center wire of the connector to ensure it is not bent.
Apr 29, 2012 | AOC LC27H060 27 in LCD TV
Televison & Video Logo
1,397 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
